pricing issues
Thread begun 10/09/2009 7:01 am by tim.wolak331163 | Last modified 10/09/2009 5:46 pm by Jason Byrnes | 3925 views | 6 replies |
tim.wolak331163
pricing issues
I have a dynamic drop down list for dog food bags that have 6lbs, 18lbs and 38lbs, each of the pounds have a drifferent price which I have two tables in my DB. I have the dynamic drop down populated with the correct items(the bag weights) but how do I get it so when the user selects a bag weight the correct price is displayed in the cart? It sees as though my filter which is filter product_id = entered value product_id is not passing the correct options to the cart. Can anyone help?
Tim
Product Category
product_cat_id
name
Product
product_id
product_cat_id
name
price
chrisw_22390844
Just to add to that... We set up a recordset that grabbed the three weights based on a specific product category (Chicken, in this case). We bound this recordset to the cart, making the price updateable via a select list. The recordset has the necessary records, but the drop down list for the prices only has a single value instead of the 3 we were expecting. What is it that we're missing regarding binding a recordset to the cart? Seems like it should be straightforward...
tim.wolak331163
support
Guys in support please help I would love to go live with this site before Monday. You can check out my issue at bnbfood.php
Thanks,
Tim
the URL:
bnbfood.php
gives a 404 page not found error.
When you add the add to cart button behavior to the page, let eacart create the select list for you.
First create a recordset that returns all 3 bag sizes.
In the Add to Cart button, set it to lookup the item ID from a recordset, chose the recordset that returns all three bag sizes.
On the bindings tab, bind all of the columns to the recordset. Set the ID column to be updateble from a select list.
once eCart has added the select list to the page, select it in design view. I nthe Property inspector, click the dynamic button.
Set it to use the recordset that returns the three bag sizes. Set the Label to the description column, set the value to the ID column.
tim.wolak331163
select list
Jason,
Thanks for the information. When I tried your suggestion, after I select the ID column to be an update able select list and then click on the dynamic button after selecting the list I can't change it because the system won't let me.
The page I gave you was wrong it is bnbfood.php
I'll be working on it so if you hit it and it messes up please try it again.
Thanks,
Tim
tim.wolak331163
working but one question
Thanks I found out what you were talking about. How do I get the price to appear in the drop down list with the bag weights?
Thanks,
Tim
you would have to manually modify the code for the select list to add the price as part of the label:
<option value="<?php echo $row_RecordsetName['ID']?>"><?php echo $row_RecordsetName['Name']?><?php echo $row_RecordsetName['Price']?></option>
