Missing SESSION_START()
Thread begun 10/09/2009 1:38 am by Cologne | Last modified 10/09/2009 12:35 pm by Jason Byrnes | 3470 views | 3 replies |
Cologne
Hello,
is it possible that session_start() is mssing, when I clear sessions befor page loads? thats DANGEROUS.
if ("" == ""){
// WA_ClearSession
$clearAll = FALSE;
$clearThese = explode(",","ID,nickname,name,level,email");
if($clearAll){
foreach ($_SESSION as $key => $value){
unset($_SESSION[$key]);
else{
foreach($clearThese as $value){
unset($_SESSION[$value]);
Can you please FIX that :-)
Denis
I have logged this in our bugbase.
in the mean time you can add:
<?php if(!session_id()) session_start(); ?>
before the clear session variable server behavior.
Cologne
Thanks.
how can I destroy the session after 20 minutes? I want the member automatic be logged out if there is no action during 20 minutes.
how does that work?
I think I need a function on every page to check, the time, when the session was created/updated. if its under 20 minutes, update time. if over 20 minutes, destroy session.
does that work with the SA rules?
Denis
No, you set that in the PHP.ini file using session.gc_maxlifetime. See the following for more information on setting the session timeout length in PHP:
12812.htm
