Cookie form field bindings don't show up on results page
Thread begun 10/08/2009 2:31 pm by tmcbinc99963 | Last modified 10/09/2009 5:22 pm by Jason Byrnes | 6450 views | 5 replies |
tmcbinc99963
I tried using the Cookies tutorial on the download page, but the form fields don't show up on my results page. Dreamweaver files are attached.
Since the forms action is to post to the cookiesresults.php page, the code for setting cookies must be on that page.
Either set the forms action to blank, and use the WebAssist Utilities -> Server Redirect server behavior to redirect to the results page after the cookies are set, or move the cookie code to the results page.
tmcbinc99963
Moved cookie code to results page - same result
I'm getting the same result after moving the code to the results page.
I looked for WA Utilities redirect Server Behavior within DW, thinking it came with ecart or cookies toolkit but not there. Also, thinking it was a separate product, looked on webassist.com, but still found nothing. Where are the WA Utilities you're referring to?
Files attached.
first, the code at the top of the page is generating an error:
session_start
should be:
session_start
Next, in both of the Set Cookie value Server behaviors, you are setting the value of the "rememberme":
if ((((isset($_POST["rememberme"]))?$_POST["rememberme"]:"") != ""))     {
setcookie("rememberme""".((isset($_POST["username"]))?$_POST["username"]:"")  .""time()+(60*60*24*30), "/"""0);
setcookie("rememberme""1"time()+(60*60*24*30), "/"""0);
line 3:
setcookie("rememberme", "".((isset($_POST["username"]))?$_POST["username"]:"")  ."", time()+(60*60*24*30), "/", "", 0);
should be:
setcookie("username", "".((isset($_POST["username"]))?$_POST["username"]:"")  ."", time()+(60*60*24*30), "/", "", 0);
I know for sure the WA Utilities behaviors are installed with Digital File Pro, they are in the server behaviors panel, click the plus button and select WA Utilities.
tmcbinc99963
New data shows up only after back and forth in browser
I've corrected the code based on your input. When previewing I get the following:
cookie.php: Type data in textfield > click 'remember me' checkbox
cookieresults.php: old data shows up
If I hit the browser back button and click 'submit' again, the new data shows up. Can't get the new data to show up on first click.
Also, I get the same results whether the session_start() is used on both pages, either page, or neither page. Thought this was necessary, or is that just in sessions?
Files are attached. Is it easier on you if I paste the code in here?
I am not able to reproduce the problem .
Each time I submit the form on cookie.php the new data is displayed on the results page.
Session_start() is only needed for sessions not cookies.
