If Then Echo Session
Thread begun 10/08/2009 2:27 pm by Cologne | Last modified 10/08/2009 6:14 pm by Cologne | 4758 views | 6 replies |
Cologne
I need help :-)
If there is no Validate entry show the session.
If
<?php echo(ValidatedField("bilderHinzufuegen","imageInfo")) ?>
is empty
show
<?php echo $_SESSION['name']; ?>
How do I write that in php, the shortest way?
Denis
Dave BuchholzBeta Tester
This will do it for you:
<?php echo(ValidatedField("bilderHinzufuegen","imageInfo ")?ValidatedField("bilderHinzufuegen","imageInfo "):$_SESSION['name']) ?>
basically what this ternary operator is doing is printing the validated entry if it exists and if it doesn't it will print the session value
Cologne
Hi dave,
this does not work, it stays the session variable, even if I change the entry.
by the way I tried to answer your question with that DFP upload size.
Denis
Denis,
I use this format all the time with VTK, especially with update forms where I need to show either the original value or the updated value if validation catches an error.
How are you using the code and for what purpose ?
Your answer worked for DFP upload size thanks.
Cologne
Dave,
i am sorry, I didnt cahnge the name of the validate entrie variable :-(
I changed it and now its:
(ValidatedField("bilderHinzufuegen","photograher") not (ValidatedField("bilderHinzufuegen","imageInfo")?
It works great, THANKS
Denis
no worries glad you got it working and thanks again for your help
Cologne
I put it on the wishlist, to have that thing back in DFP3.
Good night,
Denis
