Remove/Update Removes too much
Thread begun 10/07/2009 8:28 pm by Rich Petersen | Last modified 10/08/2009 11:52 am by Rich Petersen | 2147 views | 2 replies |
Rich Petersen
Hello!!
I just built my first cart using eCart. Excellent product.
I have multiple items with multiple options for each item.
I've debugged everything and everything works great, except one thing.
If you have for example 7 items in cart (does not matter if they are 7 unique items, or 7 of the same item just with different options, or a mixture) and you click to remove item 5. When you hit update, it will remove items 5, 6, 7.
Basically, it removes the item selected, plus any items below it.
Using same example, if you click items 3 and 6, then hit update, items 3-7 get removed.
I've looked, and can't find anything that sticks out, then again, I'm tired and about to crash, I've been coding for my real job, plus this website for my wife's business, for 19 hours now, and I'm fried, so hopefully it's something simple I've overlooked but too tired to see.
Anyway, great products, and thanks for the help! And thanks for coming out with a subscription, excellent idea which allowed me to use all your products for my side work without too much $$ outlay.
Oh, using 4.5.2/Dreamweaver CS4/PHP/MYSQL
Rich
Update your shopping cart columns and mark the options field as unique. I think that will solve this problem.
Rich Petersen
Thanks Ray,
I found the problem. I must have used the wizard twice, for I had duplicate server behaviors of the following:
eCart Continue
eCart Clear
eCart Update
eCart Checkout
Once I removed the dupes, everything worked fine.
Told you I was tired....haha
Thanks again!!
Rich
