what part of this script do I edit to get the message that arrives to look normal ?
Thread begun 10/07/2009 3:01 pm by mikeybabe | Last modified 10/10/2009 5:56 am by mikeybabe | 8349 views | 10 replies |
mikeybabe
$MailAttachments = "";
$MailBCC = "";
$MailCC = "";
$MailTo = "";
$MailBodyFormat = "";
$MailBody = "";
$MailImportance = "";
$MailFrom = "potential client|WA|mehd@hnw7.com";
$MailSubject = "sent from nathan ormsby limited web site";
$_SERVER["QUERY_STRING"] = "";
//Global Variables
$WA_MailObject = WAUE_Definition("mail.nathanormsbyltd.com","25","mehd@hnw7.com","Nathan Ormsby Limited","","");
if ($RecipientEmail) {
$WA_MailObject = WAUE_AddRecipient($WA_MailObject,$RecipientEmail);
else {
//To Entries
//Attachment Entries
//BCC Entries
//CC Entries
//Body Format
$WA_MailObject = WAUE_BodyFormat($WA_MailObject,0);
//Set Importance
$WA_MailObject = WAUE_SetImportance($WA_MailObject,"3");
//Start Mail Body
$MailBody = $MailBody . "";
foreach( $_POST as $pkey => $pval ) {
$MailBody = $MailBody . "\r\n";
$MailBody = $MailBody . (str_replace("_"," ",$pkey).": ".($pval));
//End Mail Body
$WA_MailObject = WAUE_SendMail($WA_MailObject,$MailAttachments,$MailBCC,$MailCC,$MailTo,$MailImportance,$MailFrom,$MailSubject,$MailBody);
$WA_MailObject = null;
Is it " Start Mail Body ? "
replace: .($pval)
with: .str_replace("\n","<BR />",$pval)
mikeybabe
this does not work
your syntax must be wrong ?
My syntax is correct. I copied and pasted it from a working page that is part of our html contact form solution. You must have replaced it wrong. What does your script look like now? What is the error you are getting?
mikeybabe
Hi Ray
this is what I typed in
$MailBody = $MailBody . (str_replace("_"," ",$pkey).": ".str_replace("\n","<BR />",$pval));
if this is incorrect can you cut and paste the actual line of code and I
will try it again with the correct script.
That is correct. It will replace any line breaks typed into textarea fields with br tags. You probably just have to replace the "\r\n" with "<br>" as well.
mikeybabe
do I do that like this
$MailBody = $MailBody . "\r\n"."<br />";
or this
$MailBody = $MailBody . "\r\n<br />";
or this
$MailBody = $MailBody . "<br />";
How is it supposed to look ???
They would all work.
mikeybabe
what does the r\n\ thing do anyway
And by the way that worked
it leaves big spaces between the info but
that is far better than it being bunched up on one line
So thank you Ray
I'm very happy
"\r\n" is a line break in windows. Since blank space is ignored by html, it won't add anything when viewing in html emails, but adds a blank line (or sometimes two on Linux servers) in the code.
If you sent a plain text email with no html content, you would have seen the breaks caused by "\r\n".
To have less space, remove one or all of the lines:
$MailBody = $MailBody . "<br>";
They each represent a line and you have four of them between each field. You could probably remove the two at the top and just leave the two at the bottom.
