How does redirect work within cookies toolkit?
Thread begun 10/07/2009 12:07 pm by i.edwards384429 | Last modified 10/14/2009 1:07 am by i.edwards384429 | 7434 views | 11 replies |
i.edwards384429
Hi
can I just clarify a couple of points relating to re direction?
Does the extension automaticaly create a cookie if I just type a name into the wizard window
and
Do I have to place a form on the page?
I note from an example posted in an earlier string that this may be the case
thanks
Ian
When you use the cookies toolkit you can create a cookie on a page by specifying the name. When you load that page the cookie will be created.
As for the form it is not required to have cookies on the page but there are things you can do with a form like store form values in a cookie. Please describe what you are trying to accomplish and what you have tried and the results you are getting. We can help get you going in the right direction.
i.edwards384429
re direct
Hi
this has been "sort of" answered in another thread but as a PHP cookie novice - well below that - I'm a bit lost ok totaly lost because I can't find an idiot guide on the site ;-(
Simply on an Index.php page I need the page to redirect to another page/splash screen to display special offers etc. I want to use a cookie because I need the page to display only every four weeks.
Ian
One way to do this would be to set a cookie on the splash screen page. Then on your index page you check to see if the cookie is set, if it is not then you should send the user to the splash screen page.
To do this you just need to go to Server Behaviors > Cookies Toolkit > Set Cookie value. Use the before page load trigger, then give it a name and value.
Then on your index page you can add in custom code like this to redirect if this cookie is not set:
if( !(isset($_COOKIE["<the name of your cookie>"])) )     {
header("Location: <your splash screen page>");
You would need to update the name of the cookie to match the one you set, then put in the page where you would like the user to go to.
i.edwards384429
page not found
Hi
sorry to be a pain but I added this to my index.php page above the doctype
if( !(isset($_COOKIE["<splashCookie>"])) ) {
header("Location: <http://www.ashburyblinds.co.uk/splash.php>");
In the page splash.php
I created following your instructions
if ("" == "") {
setcookie("splashCookie", "visited", time()+(60*60*24*7), "/", "", 0);
If I now upload the two files and type in www.ashburyblinds.co.uk
I get a page not found.
Clearly I've missed something out, any ideas what?
thanks
Ian
I should have explained this a little better, the values inside of the angle brackets should be replaced, including the angle brackets like this:
if( !(isset($_COOKIE["splashCookie"])) ) {
header("Location: http://www.ashburyblinds.co.uk/splash.php");
You could just put in the name of the page there as well, it does not need to be an absolute page reference, you can just have splash.php.
i.edwards384429
still no go
Hi
sorry to be a pain but still can't get this to work
in my index.php above the doctype I have
on the page splash.php in the head section I have:
function WA_cookieRedirect(CookieObj,Location,Alike,CookieName,CookieValue,RedirectTo,NewWindow) {
if ((CookieObj.getValue(CookieName)==CookieValue)==Alike) {
if (NewWindow)
window.open(RedirectTo);
else
Location.location.href=RedirectTo;
</script>
when I type in www.ashburyblinds.co.uk
I get a 400 error
thanks
Ian
i.edwards384429
additional
Hi
just noticed that my body declaration looks like this:
<body onLoad="P7_Uberlink('uberlink','menulist');WA_cookieRedirect(WA_CookieObj,document,true,'splashCookie','visited','splash.php',false)">
cheers
Ian
i.edwards384429
getting there
Hi
I seem to have made some progress.
If I type in
it does not take me to
splash.php
Perfect!!!!
However when I close Ie and re open and type in
It still takes me to
splash.php
the cookie code is:
<script src="scripts/swfobject_modified.js" type="text/javascript"></script>
if (NewWindow)
else
</script>
</head>
Any ideas?
thanks
Ian
i.edwards384429
update
Hi
think I've got it working ;-)
watch this space
Ian
