Not uploading files
Thread begun 10/07/2009 11:45 am by pardog178052 | Last modified 10/13/2009 5:14 pm by Jason Byrnes | 10259 views | 14 replies |
pardog178052
Not uploading files
Associate the page that does not send the archives to me (PHP file)
He indicates the following errors:
Errors:
Warning: session_start() [function.session-start]: Cannot send session cookie - headers already sent by (output started at /var/www/vhosts/andana.cat/httpdocs/Clients/Upload2.php:5) in /var/www/vhosts/andana.cat/httpdocs/WA_DigitalFilePro/HelperPHP.php on line 70
Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at /var/www/vhosts/andana.cat/httpdocs/Clients/Upload2.php:5) in /var/www/vhosts/andana.cat/httpdocs/WA_DigitalFilePro/HelperPHP.php on line 70
Some solution?
tom92909Beta Tester
Is the following truly correct?
<?php require_once("../WA_DigitalFilePro/HelperPHP.php"); ?>
pardog178052
I believe yes.
Attached image of the structure.
tom92909Beta Tester
Just to check let's try using this instead...
<?php require_once("WA_DigitalFilePro/HelperPHP.php"); ?>
tom92909Beta Tester
Also your form should look like this...
html:
<form action="" method="post" enctype="multipart/form-data" name="images" id="images1">
<label> </label>
<h2>Image Filename to Upload:
<input type="file" name="images" id="images">
</h2>
<input name="Submit" type="submit" id="Submit" value="Submit">
<input name="Reset" type="reset" id="Reset" value="Reset">
</form>
pardog178052
I have changed: "<?php require_once("WA_DigitalFilePro/HelperPHP.php"); ?>"
Now only it indicates the errors, does not teach any more of the page, before it taught to the errors and the rest of the page.
Errors:
Warning: require_once(WA_DigitalFilePro/HelperPHP.php) [function.require-once]: failed to open stream: No such file or directory in /var/www/vhosts/andana.cat/httpdocs/Clients/Upload2.php on line 5
Fatal error: require_once() [function.require]: Failed opening required 'WA_DigitalFilePro/HelperPHP.php' (include_path='.:.:.:') in /var/www/vhosts/andana.cat/httpdocs/Clients/Upload2.php on line 5
tom92909Beta Tester
Restore it back to ...
pardog178052
Errors:
Code Page:
error_reporting(E_ALL);
// WA_UploadResult1 Params Start
$WA_UploadResult1_Params = array();
// WA_UploadResult1_1 Start
$WA_UploadResult1_Params["WA_UploadResult1_1"] = array(
'UploadFolder' => "Enviaments/",
'FileName' => "",
'DefaultFileName' => "",
'ResizeType' => "0",
'ResizeWidth' => "0",
'ResizeHeight' => "0",
'ResizeFillColor' => "" );
// WA_UploadResult1_1 End
// WA_UploadResult1 Params End
WA_DFP_SetupUploadStatusStruct("WA_UploadResult1");
if($_SERVER["REQUEST_METHOD"] == "POST"){
WA_DFP_UploadFiles("WA_UploadResult1", "images", "0", "", "false", $WA_UploadResult1_Params);
if($WA_DFP_UploadStatus["WA_UploadResult1"]["statusCode"] == 1){
$WA_Redirect_URL = "Clients/Upload2.php";
$WA_Redirect_KeepQS = false;
if ($WA_Redirect_URL != "") {
if ($WA_Redirect_KeepQS && $WA_Redirect_URL != "" && isset($_SERVER["QUERY_STRING"]) && $_SERVER["QUERY_STRING"] !== "") {
$WA_Redirect_URL .= ((strpos($WA_Redirect_URL, '?') === false)?"?":"&").$_SERVER["QUERY_STRING"];
header("Location: ".$WA_Redirect_URL);
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd">
<html xmlns="http://www.w3.org/1999/xhtml"><head>
<title>Edicions i propostes culturals Andana - Enviament d'arxius</title>
<link href="../cssandana/andana.css" rel="stylesheet" type="text/css" media="all" />
<script src="../Llibres/PluginLab/Scripts/PL_Layer.js" type="text/javascript">/* Used by PL_LayerWindow */</script>
<script src="../WA_DigitalFilePro/jquery-blockui-formprocessing.js" type="text/javascript"></script>
</head>
<body onload="P7_initPM(1,0,1,-20,10)">
<div id="cuerpo">
<?php include("../Include/capsalera.php"); ?>
<div id="contenido">
<div id="columnagran">
<div id="images1_ProgressWrapper">
<label> </label>
</h2>
</form>
</div>
</div>
</div>
</div>
<div id="w3c"> <a href="http://validator.w3.org/check?uri=http%3A%2F%2Fwww.andana.cat%2FPremsa.php"><img src="../W3C/xhtml1.gif" alt="Valid XHTML 1.0 Strict" height="15" width="80" /></a> <a href="http://jigsaw.w3.org/css-validator/validator?uri=http%3A%2F%2Fwww.andana.cat%2FPremsa.php&profile=css21&usermedium=all&warning=1"><img src="../W3C/css21.gif" alt="¡CSS Válido!" style="border:0;width:80px;height:15px" /></a> </div>
<?php include("../Include/pie.php"); ?>
</div>
</div>
<div id="images1_ProgressMessageWrapper" class="blockUIOverlay" style="display:none;">
WADFP_SetProgressToForm('images1', 'images1_ProgressMessageWrapper', WADFP_Theme_Options['Bar:DesertSpice']);
</script>
<div id="images1_ProgressMessage" >
<p style="margin:10px; padding:5px;" ><img src="../WA_DigitalFilePro/images/desert-bar.gif" alt="" title="" style="vertical-align:middle;" />&nbsp;&nbsp;Please wait</p>
</div>
</div>
</body>
</html>
the problem is caused by an extra blank space at the end of line 4:
should be:
PHP is picky about blank spaces.
pardog178052
It does not give errors, redirect the page correctly, but the file does not go to the indicated folder: " Enviaments"
