Insert from login page
Thread begun 10/07/2009 11:38 am by rogersds267040 | Last modified 10/19/2009 11:25 am by Jason Byrnes | 7275 views | 9 replies |
rogersds267040
I'm trying to insert the userID stored in a session into a database and it just will not insert. What am I doing wrong?
Below is the login page code:
<?php require_once('Connections/first.php');?>
<?php require_once("WA_DataAssist/WA_AppBuilder_PHP.php"); ?>
<?php require_once("WA_SecurityAssist/WA_SHA1Encryption.php"); ?>
<?php require_once( "WA_SecurityAssist/Helper_PHP.php" ); ?>
if ((((isset($_POST["remembermeoption"]))?$_POST["remembermeoption"]:"") != "")) {
setcookie("RememberMePWD", "".((isset($_POST["userpassword"]))?$_POST["userpassword"]:"") ."", time()+(60*60*24*30), "/", "", 0);
setcookie("RememberMeUN", "".((isset($_POST["username"]))?$_POST["username"]:"") ."", time()+(60*60*24*30), "/", "", 0);
if (isset($_POST["LogIn_x"]) && !isset($_POST["remembermeoption"])) {
setcookie("RememberMePWD", "", time()+(60*60*24*30), "/", "", 0);
setcookie("RememberMeUN", "", time()+(60*60*24*30), "/", "", 0);
if(isset($_POST["LogIn_x"])){
$WA_Auth_Parameter = array(
"connection" => $first,
"database" => $database_first,
"tableName" => "users",
"columns" => explode($WA_Auth_Separator,"userCSRID".$WA_Auth_Separator."userpassword"),
"columnValues" => explode($WA_Auth_Separator,"".((isset($_POST["username"]))?$_POST["username"]:"") ."".$WA_Auth_Separator."".WA_SHA1Encryption(((isset($_POST["userpassword"]))?$_POST["userpassword"]:"")) .""),
"columnTypes" => explode($WA_Auth_Separator,"text".$WA_Auth_Separator."text"),
"sessionColumns" => explode($WA_Auth_Separator,"userID".$WA_Auth_Separator."userLevel".$WA_Auth_Separator."userCSRID".$WA_Auth_Separator."userActive".$WA_Auth_Separator."firstLogIn"),
"sessionNames" => explode($WA_Auth_Separator,"userID".$WA_Auth_Separator."userLevel".$WA_Auth_Separator."userCSRID".$WA_Auth_Separator."userActive".$WA_Auth_Separator."firstLogIn"),
"successRedirect" => "users_Profile.php",
"failRedirect" => "users_LogIn.php?failed=1",
"gotoPreviousURL" => TRUE,
"keepQueryString" => TRUE
WA_AuthenticateUser($WA_Auth_Parameter);
// WA Application Builder Insert
if ($_SERVER["REQUEST_METHOD"] == "POST") // Trigger
$WA_connection = $first;
$WA_table = "user_LogTime";
$WA_sessionName = "user_LogTime_logID";
$WA_redirectURL = "";
$WA_keepQueryString = false;
$WA_indexField = "logID";
$WA_fieldNamesStr = "logUserID";
$WA_fieldValuesStr = "".$_SESSION['userCSRID'] ."";
$WA_columnTypesStr = "none,none,NULL";
$WA_connectionDB = $database_first;
$insertParamsObj = WA_AB_generateInsertParams($WA_fieldNames, $WA_columns, $WA_fieldValues, -1);
$WA_Sql = "INSERT INTO `" . $WA_table . "` (" . $insertParamsObj->WA_tableValues . ") VALUES (" . $insertParamsObj->WA_dbValues . ")";
$_SESSION[$WA_sessionName] = mysql_insert_id();
if ($WA_redirectURL != "") {
$theValue = (!get_magic_quotes_gpc()) ? addslashes($theValue) : $theValue;
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
$theValue = ($theValue != "") ? "'" . doubleval($theValue) . "'" : "NULL";
break;
case "date":
$theValue = ($theValue != "") ? "'" . date("Y-m-d",strtotime($theValue)) . "'" : "NULL";
break;
case "time":
$theValue = ($theValue != "") ? "'" . date("H:i:s",strtotime($theValue)) . "'" : "NULL";
break;
case "datetime":
$theValue = ($theValue != "") ? "'" . date("Y-m-d H:i:s",strtotime($theValue)) . "'" : "NULL";
break;
case "defined":
break;
return $theValue;
It looks like you are storing the userCSRID value in a session variable and then trying to insert that session variable into your user_LogTime table. Do you get any record to insert into the table? Have you checked this session variable to ensure that it is has a value?
You can do a check just after the trigger for the insert by adding in this code:
die("the userCSRID is: " . $_SESSION['userCSRID']);
So long as this session variable has a value it should be inserted into the table. Also, I noticed the trigger for your login was login button pressed but the trigger for your insert is any page post. You should update the trigger for the insert to be like the trigger for your login.
rogersds267040
It still doesn't insert into the table.
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
break;
case "date":
break;
case "time":
break;
case "datetime":
break;
case "defined":
break;
return $theValue;
if (isset($_POST["LogIn_x"])) // Trigger
$WA_fieldValuesStr = "".((isset($_POST["logUserID"]))?$_POST["logUserID"]:"") ."";
$WA_columnTypesStr = "',none,''";
<div id="LogInContainer" class="WAATK">
<form method="POST" name="WAATKLogInForm" id="WAATKLogInForm">
<h1>Please Log In</h1>
<table class="WAATKDataTable" cellpadding="0" cellspacing="0" border="0">
<?php if(WA_Auth_RulePasses("Login Failed")){ // Begin Show Region ?>
<tr>
<th>&nbsp;</th>
<td><span class="textfieldServerError" >The login information provided is not valid. Please try again.</span></td>
</tr>
<?php } // End Show Region ?>
<tr>
<th>Enter your CSRID</th>
<td><span id="sprytextfield1">
<input type="text" class="WAATKTextField" name="username" value="<?php echo((isset($_COOKIE["RememberMeUN"]) && isset($_COOKIE["RememberMePWD"]))?$_COOKIE["RememberMeUN"]:"") ?>" />
<span class="textfieldRequiredMsg">A value is required.</span></span></td>
</tr>
<tr>
<th>Password</th>
<td><span id="sprypassword1">
<input type="password" class="WAATKTextField" name="userpassword" value="<?php echo((isset($_COOKIE["RememberMePWD"]))?$_COOKIE["RememberMePWD"]:"") ?>" />
<span class="passwordRequiredMsg">A value is required.</span></span></td>
</tr>
<tr>
<th class="WAATKDataTableHeader"><input type="checkbox" name="remembermeoption" <?php echo((isset($_COOKIE["RememberMeUN"]))?"checked":"") ?> value="1" /></th>
<td class="WAATKDataTableCell">Remember me</td>
</tr>
<tr>
<th class="WAATKDataTableHeader">&nbsp;</th>
<td class="WAATKDataTableCell"><span class="WAATKDataTableHeader">(<a href="users_EmailPW.php">forgot</a> your password?)</span></td>
</tr>
</table>
<div class="WAATKButtonRow">
<input type="image" hspace="0" vspace="0" border="0" name="LogIn" id="LogIn" value="Log In" alt="Log In" src="WA_DataAssist/images/Slate/Refined_insert.gif" />
<input name="logUserID" type="hidden" id="logUserID" value="<?php echo $_SESSION['userCSRID']; ?>" />
</div>
</form>
</div>
var sprytextfield1 = new Spry.Widget.ValidationTextField("sprytextfield1", "none", {validateOn:["blur"]});
var sprypassword1 = new Spry.Widget.ValidationPassword("sprypassword1", {validateOn:["blur"]});
</script>
Did you put in the die statement? I did not see it, please add this in and test the insert, instead of inserting it should go to a blank white screen with a message about the session variable.
In the future in you would like to post your pages please attach them to your post in a zip archive or a text file.
rogersds267040
I have attached the login.php and profile.php page.
It looks like your pages did not get attached to your post. You must have them in a zip file to attach them. Did you get any output from the die statement? I think it is just a problem with the session values that should be set. This test should tell us more about what the problem is.
rogersds267040
Find the attached pages. When I add the code Im directed to a blank page.
The Authenticate user server behavior is redirecting to the users_Profile.php page before the insert Record behavior can run.
Double click the Authenticate user server behavior and remove the redirect to the users_Profile.php page, then double click the Insert Record server behavior and set it to redirect to the users_Profile.php page after the insert takes place.
rogersds267040
Thanks it work
You're welcome.
