Applying encryption with Security Assist and Data Assist
Thread begun 10/07/2009 10:06 am by David Stringer | Last modified 10/09/2009 7:24 am by Ray Borduin | 7635 views | 11 replies |
David StringerBeta Tester
I am endeavouring to apply encryption to a particular site I had originally used Addt on. I have removed all the code that appertained from that programme!
I am presently testing the pages on my local machine.
Having built the necessary pages, following exactly the Solution Recipes in SA, I keep getting the same problem. Having added the php error reporting to the page, the page returns the following error:
Warning: require_once(../WA_SecurityAssist/WA_SHA1Encryption.php) [function.require-once]: failed to open stream: No such file or directory in C:\wamp\www\UpsallStud\assets\users_Registration.php on line 6
Fatal error: require_once() [function.require]: Failed opening required '../WA_SecurityAssist/WA_SHA1Encryption.php' (include_path='.;C:\php5\pear') in C:\wamp\www\UpsallStud\assets\users_Registration.php on line 6
Checking my files - there is no SHA1Enryption.php page to be found.
Thinking I could circumvent this by downloading the Security Assist extension again and disposing of the winfilecache.dat file, I did so. Unfortunately, this didn't help one jot!
Has anyone any ideas on what might be going wrong?
EDIT: I've noticed that in the file extension, it has shown the ph with one space and then p, but this is alright in the code that I cut and pasted!!
jenkolaka19379118
For some very strange reason this happened to me too. I had to copy the SHA1.php file from another site and paste it into my current sa folder in my web directory
Unfortunately, I've never used this programme until now, so don't have the luxury of being able to copy it from anywhere. I presume that it is generated on the hoof! I shall have to wait until someone from WebAssist sees my plight and provides an answer.
Thank you for your observations.
You could try adding encryption to another page.
You could search your DW configuration for that file and copy it from there.
It should copy it as it writes the file to your page. Make sure the page you add it to is saved and in a php defined site and it should copy the file automatically.
Here is a zip file that contains the needed file. Copy the file from the zip file to the WA_SecurityAssist Folder.
Hi Jason,
Thank you for this. I've downloaded the files and will have a play with them tomorrow. Too late to be doing it now!
I did try to copy the files to the folder in my site and was told by Windows that they were there. I assure you, they were not unless they were hidden. I used Windows Explorer to copy them to the page in the folder and they then did appear in DW. Weird goings-on!
I'll let you know how I get on.
Bug?
I have copied the files as explained and everything is working OK now. Thank You.
I cannot help but think that there might be a bug which is not allowing the programme to write the necessary details to disc. Only because this has occurred on two separate computers, not just one. OR there is something wrong with my computers.:rolleyes:
Yes, you are not the first to report it either, so I think it might be a bug. I'll try to do some testing to see if I can reproduce it. What version of Dreamweaver and operating system were you using?
Were you dragging and dropping, or clicking a lightning bolt, or clicking the insert button in the bindings panel to add it to the page?
Most likely the issue is specific to the exact usage scenario you were going through and knowing that might help me correct it.
Hi Ray,
I'm using Dreamweaver CS4 and XP Pro.
Just to make it easy for you, I was following Mark's Solution Recipes under the Support & Training. (To the letter!!) I don't suppose you've seen them though. Not sure on every move I made, but there were no drags and drops!
Hope this helps.
