Showing text instead of a value in an Email
Thread begun 10/07/2009 9:46 am by Paul | Last modified 12/03/2009 1:00 pm by Eric Mittman | 6178 views | 13 replies |
PaulBeta Tester
I've setup my registration page to auto-send a confirmation email to the registrant.
The email body contains the following
((isset($_POST["UserNewsletter"]))?$_POST["UserNewsletter"]:"");
Which displays a numerical value, either 0 or 1.
I need to convert the value to text, thus:
If 0 then show "No" if 1 then show "Yes"
Any ideas please?
Thank you, Paul.
This is a perfect example of when it is appropriate to use a ternary expression in PHP. It will evaluate a condition and use one value for true and another for false. This is the line of code you posted, after the ? is when the expression evaluates to true and after the : is when it evaluates to false. So you can alter it by also checking if the value is one, then output either yes or no like this:
(isset($_POST["UserNewsletter"]) && $_POST["UserNewsletter"]  == '1')?"yes":"no");
PaulBeta Tester
Eric,
Thanks for reponse.
This is how i have presented it in my WAUE_registration_1.php file
$MailBody = $MailBody . "<p>Newsletter: ";
$MailBody = $MailBody . (((isset($_POST["UserNewsletter"]) && $_POST["UserNewsletter"] == '1')?"Yes":"No");
However, something is amiss because the email is not triggering.
Any ideas on where i could be going wrong?
If this is the only update then it should not affect how the email is triggered. Can you post back and include a copy of the page with the UE server behavior on it as well as a copy of the WAUE file that you altered in a zip archive. I will take a look to see if I can spot a problem.
PaulBeta Tester
Eric,
Zip files attahed
Paul
I think the issue may have just been a syntax problem. The code that I posted looks like it is missing a left parenthesis, in the file you posted there is one extra left parenthesis in the code. Try updating line 60 of WAUE_registration_3.php to be like this:
$MailBody = $MailBody .  ((isset($_POST["UserNewsletter"]) && $_POST["UserNewsletter"]  == '1')?"Yes":"No");
Please update this and give it a try, I think it should work after this.
PaulBeta Tester
Eric,
Issue resolved. thank you.
Awesome, I'm always happy to hear that.
jenkolaka19379118
Similar Question
Hi Eric,
I am having a similar problem. The only difference is I am using a dynamic dropdown menu. A user can select one choice and I want the users selection to be echoed in an UE body. The problem I am having is that when I simply bind the menu to my email body, the menu displays the ID instead of the label.
Would you be able to describe to me how I would get the label (description field in database) to display in the email instead of the ID (primary key field in database).
This is a problem in general when you are working with select lists. The value that is submitted will not include the label. The best way to work around this would be to set the label of the selected index to the value of a hidden form element. You could then reference this hidden form element in the body of the email to get at the label.
The other way you could do this would be to set the labels and values to the same thing so that the label is submitted and not an id.
If you would like to go the first route I have an example page with a js function that is setting the label for the selected index to the value of a form element. You can use this same function call, just make sure to update it to include the name of the hidden form element you create to hold this value.
