iexplorer error ... irite (re) format source code
Thread begun 10/07/2009 9:26 am by info321189 | Last modified 10/11/2009 10:54 pm by info321189 | 5561 views | 7 replies |
info321189
Hello, in pages created by irite I use swfobject for flash animations, to do this I paste the source code from swf online generator, first time I save the page work fine in any browser, when I update the page irite reformat the source code (delete spaces and return line) this generate a lot of errors in iexplorer and the page not working fine...
How I can mantain the spaces and format code ?
Is there any formatting occurring for the results that you load into the editor? If it is ok the first time but not ok when updating this indicates that there is some extra formatting occurring during the insert or when getting the info back.
The places to check for this would be the initial value for the iRite editor, this is on the first page of the iRite wizard.
You should also check the value is being inserted and updated, if there is any formatting here it can cause something like this. Please check for this extra formatting and remove it if it exists. Let us know the result, also if you can post back with links to the pages or the pages themselves in a zip archive we would be able to get a better idea of what is occurring.
info321189
Hello Eric,
I try but continue to reformat the source...
my js configuration for the editor is:
-- BEGIN --
// Custom configuration for iRite
FCKConfig.SkinPath = 'skins/silver/'; // relative to fckeditor/editor/fckeditor.html
FCKConfig.DocType = '<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">';
FCKConfig.AutoDetectLanguage = false;
FCKConfig.DefaultLanguage = 'en';
FCKConfig.StartupFocus = false;
FCKConfig.FullPage = false;
FCKConfig.BaseHref = '';
FCKConfig.DefaultLinkTarget = '_blank';
FCKConfig.ToolbarSets["Custom"] = [
['Source','DocProps','-','NewPage','Preview','-','Templates'],
['Cut','Copy','Paste','PasteText','PasteWord','-','Print','SpellCheck'],
['Undo','Redo','-','Find','Replace','-','SelectAll','RemoveFormat'],
['Form','Checkbox','Radio','TextField','Textarea','Select','Button','ImageButton','HiddenField'],
['Bold','Italic','Underline','StrikeThrough','-','Subscript','Superscript'],
['OrderedList','UnorderedList','-','Outdent','Indent'],
['JustifyLeft','JustifyCenter','JustifyRight','JustifyFull'],
['Link','Unlink','Anchor'],
['Image','Flash','Table','Rule','Smiley','SpecialChar','PageBreak'],
['Style','FontFormat','FontName','FontSize'],
['TextColor','BGColor'],
['FitWindow','-','About']
]; /* Toolbar end */
FCKConfig.ForceStrongEm = true;
FCKConfig.FormatIndentator = ' ';
FCKConfig.EnterMode = 'p';
FCKConfig.FillEmptyBlocks = false;
FCKConfig.FormatOutput = false;
FCKConfig.FormatSource = false;
FCKConfig.IncludeGreekEntities = false;
FCKConfig.IncludeLatinEntities = false;
FCKConfig.ProcessHTMLEntities = false;
FCKConfig.ProcessNumericEntities = false;
FCKConfig.AdditionalNumericEntities = '';
FCKConfig.ForcePasteAsPlainText = true;
FCKConfig.CleanWordKeepsStructure = true;
FCKConfig.EditorAreaCSS = '../../css/screen.css'; // relative to fckeditor/editor/fckeditor.html
FCKConfig.BodyClass = 'editor';
FCKConfig.StylesXmlPath = '../custom/default1.xml'; // relative to fckeditor/editor/fckeditor.html
-- END --
the iRite code in update page is
// WebAssist iRite: Rich Text Editor for Dreamweaver
$WARichTextEditor_1 = CreateRichTextEditor ("htmleditor", "WA_iRite/", "640px", "480px", "Custom", "../custom/default1.js", "".$row_WADApages['webpage'] ."");
if I paste the first time a code like this:
-- BEGIN --
<div>
<object classid="clsid:D27CDB6E-AE6D-11cf-96B8-444553540000" width="300" height="100" id="swf" name="flash">
<param name="movie" value="test.swf" />
<param name="quality" value="high" />
<!--[if !IE]>-->
<object type="application/x-shockwave-flash" data="test.swf" width="300" height="100">
<!--<![endif]-->
<a href="http://www.adobe.com/go/getflashplayer"><img src="http://www.adobe.com/images/shared/download_buttons/get_flash_player.gif" alt="Get Adobe Flash player" />
</a>
<!--[if !IE]>-->
</object>
<!--<![endif]-->
</object>
</div>
-- END --
When I update I get:
-- BEGIN --
<div><object classid="clsid:D27CDB6E-AE6D-11cf-96B8-444553540000" width="300" height="100" id="swf" name="flash">
<!--[if !IE]>-->
<!--<![endif]-->
</a>
<!--[if !IE]>-->
</object> <!--<![endif]--></div>
-- END --
This cause errors in iexplorer... :-(
The configuration file is probably not the source of the problem. This is likely an issue on the page that iRite is applied to directly. If you can please post back with the insert and update pages that have iRite applied to them. You can just put them in a zip archive and attach that to your post. I will check out these pages to try and determine what is going wrong.
info321189
Thankyou very much for support Eric.
I attach the two pages.
The pages you posted with the iRite code on them do not seem to be doing any formatting of the data that is in them. Do you have a link to a live page where the error is occurring? Also please include information about the swf that was originally placed in the iRite instance.
info321189
Hello Eric, I just paste the code changing names, the live pages are under administration area, I can send you a private link ?
info321189
Solved !
Hello, the <object> tag are inside a <div> element, I just add in the irite page configuration this line:
FCKConfig.ProtectedSource.Add( /<div[\s\S]*?<\/div>/gi);
