Error out of memory dataassist mac dw4
I am getting this error,
I have tryed
1. reinstalling the dataassist extention
2. renaming the configuration folder
what should i try next?
I have tryed
What is the version of DataAssist that you have installed?
There are two things you should try. The first is to delete the cache file that is in the configuration folder. I'm including a link to a troubleshooting page with instructions on deleting this file, it will be the MacFileCache file for you.
146/
The other thing to try is to make sure you have all of your panels closed before you run the wizard. A while back I saw an issue like this that would happen when the files panel and others were open, closing them before running the wizard would help with this. Please post back and let us know your results.
Very strange but i moved the files to a PC and had the Same error in CS3? so i deleted the server behavior and redid it and the error went away.
Thanks!
That is strange, but good news. If the issue happened again for a set of files then it may have to do with that set of files, but without getting consistent reproduction for the problem it is difficult to say what was causing it. Let us know if you experience the issue again.
