powerstore in italian?
Thread begun 10/07/2009 2:05 am by info259249 | Last modified 10/27/2009 9:34 am by Jason Byrnes | 5819 views | 9 replies |
info259249
Hello.
I would like to know if it's possible to customize powerstore in italian language.
Could i replace the english terms with the italian ones by dreamweaver?
Thanks,
Marco
Yes, you can replace all of the text in PowerStore with Italian using Dreamweaver.
Start by editing the text on the template, then fins any text on the other pages that is left to change.
info259249
Does it work only with paypal?
Thanks for the answer: i also would like to know if Power Store works only with Paypal and Authorize.net, or if is it possible to use it with any other gateways (ex. bank server) too?
Regards,
Marco
PowerStore is set up to work with Paypal Payments pro and Authorize.Net payment gateways.
If you own eCart, you can use eCart to change the checkout to use one of the other Local Checkout payment gateways that are included in eCart:
# Local payment gateway support
* Authorize.Net AIM
* LinkPoint API
* PayPal Website Payments Pro
* PayFlow Pro (PHP only)
If you wish to use a gateway not supported by eCart, you would need to hand code the logic to process the transaction with that gateway yourself.
info259249
paypal italy?
Thanks.
Does it work also with the italian version of Paypal?
Regards,
Marco
NO, only PayPal Payments Pro US.
info259249
ecart?
... is it the same for the WA ecart? Does it work only with the US gateway?...
eCart has support for PayPal Payments Pro US and PayPal Payments Pro UK,
info259249
changing the ecart form action...
What i need to know is if i can simply modify the ecart form action to use the PowerStore with a generic bank server, exchanging the code with that one supplied by the bank... Thanks...
Yes, you could change the code that processes the transaction through paypal to process through your bank server.
You will likely have to modify the code provided by the bank to get it to work, If you are comfortable coding in PHP, it should not be that difficult.
