Store Summary and Store Details
Thread begun 10/06/2009 3:56 pm by gcollins189987 | Last modified 10/08/2009 3:42 pm by Jason Byrnes | 2920 views | 4 replies |
gcollins189987
When I use the store summary and store details wizards my site adds this first order to these tables. I then do a second order and it updates/deletes the first order instead of adding a new record.
Any ideas why this would be happening?
gcollins189987
Using some response.write()'s I came up with this.
First time through:
ADD STUDENT1: INSERT INTO tbl_Students (StudentBuyerID,StudentUserName,StudentPassword,StudentGender,StudentFirstName,StudentLastName,StudentEmail,StudentAddress1,StudentAddress2,StudentCity,StudentStateProv,StudentCountry,SudentZipPost) VALUES (1,'core','learning','1','Core','Learning','g@learning.com','2244 Somewhere','','Port Hope','Ontario','Canada','M2P 2A9')
ADD STUDENT2: SELECT StudentID FROM tbl_Students WHERE StudentBuyerID = 1 AND StudentUserName LIKE 'core%' AND StudentPassword LIKE 'learning%' AND StudentGender LIKE '1%' AND StudentFirstName LIKE 'Core%' AND StudentLastName LIKE 'Learning%' AND StudentEmail LIKE 'g@learning.com%' AND StudentAddress1 LIKE '2244 Somewhere%' AND StudentAddress2 LIKE '' AND StudentCity LIKE 'Port Hope%' AND StudentStateProv LIKE 'Ontario%' AND StudentCountry LIKE 'Canada%' AND SudentZipPost LIKE 'M2P 2A9%' ORDER BY StudentID DESC
ADD CART SUMMARY3: insert into tbl_Orders (OrderReferenceID,OrderBuyerID,OrderStudentID,OrderSubTotal,OrderDiscount,OrderTax,OrderTotal,OrderCardType,OrderCardNumber,OrderCardHolder,OrderCardExpire) values ('2009100618402201475',1,1,'$40.00','$0.00','$5.20','$45.20','Visa','......1111','Core Learning','02/10')
ADD CART SUMMARY4: select OrderID from tbl_Orders where OrderReferenceID='2009100618402201475' AND OrderBuyerID=1 AND OrderStudentID=1 AND OrderSubTotal='$40.00' AND OrderDiscount='$0.00' AND OrderTax='$5.20' AND OrderTotal='$45.20' AND OrderCardType='Visa' AND OrderCardNumber='......1111' AND OrderCardHolder='Core Learning' AND OrderCardExpire='02/10' order by OrderID DESC
ADD CART DETAIL1: Delete from tbl_OrderDetails where DetailOrderID = 1
ADD CART DETAIL2: insert into tbl_OrderDetails (DetailOrderID,DetailCourseID,DetailCourseName,DetailQuantity,DetailPrice,DetailSubscriptionType) values (1,286079434,'English Grammar I','1','$40.00',4)
Second time through (do not need to add student because we added firsttime):
ADD CART SUMMARY1: select OrderID from tbl_Orders where OrderID = 1 order by OrderID DESC
ADD CART SUMMARY2: update tbl_Orders SET OrderReferenceID = '2009100618441101478', OrderBuyerID = 1, OrderStudentID = 1, OrderSubTotal = '$40.00', OrderDiscount = '$0.00', OrderTax = '$5.20', OrderTotal = '$45.20', OrderCardType = 'Visa', OrderCardNumber = '......1111', OrderCardHolder = 'Core Learning', OrderCardExpire = '03/11' where OrderID = 1
ADD CART DETAIL2: insert into tbl_OrderDetails (DetailOrderID,DetailCourseID,DetailCourseName,DetailQuantity,DetailPrice,DetailSubscriptionType) values (1,286079302,'English Grammar II - Essentials','1','$40.00',4)
The session needs to be destroyed when an order goes through to begin a new session.
On the Checkout success page, add the following after the </html> tag:
Session.Abandon
gcollins189987
That worked.
But this completely logs my user out.
If I don't want them to be logged out what session variables must I clear so that I don't have the problem I was having.
On the confirm page, open the Store order Summary Behavior. Note the name that is set inn the Store As option.
Do the same for the Store order details serer behavior.
Then add asp code to set those sessions to be blank:
Session("<Summary Session Variable Name>") = ""
Session("<ddetails Session Variable Name>") = ""
