Pro Maps 1.05 version
Thread begun 10/06/2009 6:56 am by mparker99255945 | Last modified 10/13/2009 3:24 pm by Jason Byrnes | 2507 views | 3 replies |
mparker99255945
I am trying to set the zoom level and have succeeded with 2 locations included in the map, but when I add a 3rd or 4th the map does not display, only the last inserted pin with no map background. Has anyone enclountered this problem or am I doing something wrong.
can you post a link to a page demonstrating the problem so we can investigate the cause.
mparker99255945
Maps Pro version 1.05
Hi Jason,
Have solved the problem, you have to add the zoom overlay into the location which appears as ther default location and it works. In this case I had to insert it in location 4 not location 0 which was the first one in the code listing attached to the map page.
many thanks
Mike
OK, glad to hear it is working.
