Single Record Update
Thread begun 10/05/2009 9:57 pm by gcollins189987 | Last modified 10/06/2009 3:05 pm by Eric Mittman | 2044 views | 2 replies |
gcollins189987
My update doesn't seem to be updating my record.
I don't get any errors it just doesn't seem to be updating my column. Before the page is loaded it is supposed to update a single record.
It is using two url parameters for the insert. First one to find the record and the second one is the value I want to insert.
Example:
uniquecode = gcollins
userid = 543351169_31263066234_r
Here is my code:
<%@LANGUAGE="VBSCRIPT" CODEPAGE="1252"%>
<!--#include file="WA_DataAssist/WA_AppBuilder_VB.asp" -->
<!--#include file="Connections/conn_Core.asp" -->
If (NOT Session("UserExisting")) Then %>
' WA Application Builder Update
if ("" = "") then
WA_connection = MM_conn_Core_STRING
WA_table = "tbl_Students"
WA_redirectURL = ""
WA_keepQueryString = true
WA_indexField = "StudentUserName"
WA_fieldNamesStr = "StudentKPID"
WA_fieldValuesStr = "Request.QueryString(" & Chr(34) & "userid" & Chr(34) & ")"
WA_columnTypesStr = "',none,''"
WA_comparisonStr = "="
WA_fieldNames = Split(WA_fieldNamesStr,"|")
WA_fieldValues = Split(WA_fieldValuesStr,"|")
WA_columns = Split(WA_columnTypesStr,"|")
WA_comparisions = Split(WA_comparisonStr, "|")
WA_where_fieldValuesStr = "Request.QueryString(" & Chr(34) & "uniquecode" & Chr(34) & ")"
WA_where_columnTypesStr = "',none,''"
WA_where_comparisonStr = "="
WA_where_fieldNames = Split(WA_indexField,"|")
WA_where_fieldValues = Split(WA_where_fieldValuesStr,"|")
WA_where_columns = Split(WA_where_columnTypesStr,"|")
WA_where_comparisions = Split(WA_where_comparisonStr, "|")
updateParamsObj = WA_AB_generateInsertParams(WA_fieldNames, WA_columns, WA_fieldValues, -1)
WhereObj = WA_AB_generateWhereClause(WA_where_fieldNames, WA_where_columns, WA_where_fieldValues, WA_where_comparisions)
set MM_editCmd = Server.CreateObject("ADODB.Command")
MM_editCmd.ActiveConnection = WA_connection
MM_editCmd.CommandText = "UPDATE " & WA_table & " SET " & updateParamsObj(3) & " WHERE " & WhereObj & ""
MM_editCmd.Execute()
MM_editCmd.ActiveConnection.Close()
if (WA_redirectURL <> "") then
if (WA_keepQueryString AND Request.QueryString <> "" AND Request.QueryString.Count > 0) then
if (inStr(WA_redirectURL,"?") > 0) then
WA_redirectURL = WA_redirectURL & "&"
else
WA_redirectURL = WA_redirectURL & "?"
end if
WA_redirectURL = WA_redirectURL & Request.QueryString
end if
Response.Redirect(WA_redirectURL)
end if
end if
Else
Response.Redirect("************")
End If
Any Thoughts?
gcollins189987
I am relatively new at these webassist tools so I have been banging my head at this one, and I am starting to get a lump.
Any body have some ideas?
It looks like the trigger is set to before page load. You should only do this if you can ensure that the variables will be present before the page loads.
Another thing you can try with this insert is to set the redirect page. After setting this you should be able to test the page and get to the redirect page. Please give this a try and let us know what you experience. This will let us know if you are getting through the server behavior or not.
