Error message with iRite
Thread begun 10/05/2009 1:23 pm by joneil375464 | Last modified 10/14/2009 7:47 pm by joneil375464 | 3157 views | 4 replies |
joneil375464
Error message with iRite executing timer in WA_iRite.htm
After entering in serial # Selecting the form field to use
While executing timer in WA_iRite.htm, the following JavaScript error(s) occurred:
At line 162 of file "C:\Program Files\Adobe\Adobe Dreamweaver CS4\Configuration\Shared\Webassist\RichTextEditor\iRiteShard.js":rt.SB.Nodes has no properties
what is going on!!!
Have you tried clearing out your cache file, or clearing your configuration folder? This looks like it may be an issue with one of those. Here is a link to a troubleshooting page that lists the steps you should take to clear out the cache file and the configuration folder is needed. Please give this a try and let us know if the issue persists.
146/
joneil375464
configuration file fix
I will try this and see what happens. Hoepfully this solves the problem.
Definitely let us know if the issue persists.
joneil375464
Seems to be working now... will try to use it
