using DD with preselected values
Thread begun 10/04/2009 10:20 am by barbara224891 | Last modified 10/15/2009 11:29 am by Jason Byrnes | 7626 views | 8 replies |
barbara224891
I've got a parent list (organizations) and a child list(contacts). When the page loads, I would like it to show a particular value in the parent list as selected, that value depending on a recordset value. I tried selecting the parent dropdown and applying the set selected in list behavior, but that didn't work. I realized one reason it didn't work is that it was initially applied onchange, just like the populate list from array behavior. I tried changing it to onload, but still no luck.
If I weren't using dynamic dropdowns, I'd do this with the bind to dynamic source button in the properties window, but that seems not to work.
here's the code for the parent list:
<select name="orgID" id="orgID" onchange="WA_FilterAndPopulateSubList(contacts_WAJA,MM_findObj('orgID'),MM_findObj('contact'),1,0,false,': ')" onload="WA_setSelectionsInChildList(MM_findObj('orgID'),<?php echo $row_project['agency']; ?>)">
<option value="" <?php if (!(strcmp("", $row_project['agency']))) {echo "selected=\"selected\"";} ?>>-- select --</option>
do {
<option value="<?php echo $row_agencies['orgID']?>"<?php if (!(strcmp($row_agencies['orgID'], $row_project['agency']))) {echo "selected=\"selected\"";} ?>><?php echo $row_agencies['name']?></option>
} while ($row_agencies = mysql_fetch_assoc($agencies));
</select>
I'd like the child list to also prepopulate according to the recordset, but until I can get the parent working, that one seems unlikely.
Thanks for your help.
apply the Dynaminc Dropdowns set selected in list behavior to the onLoad event of the body tag.
barbara224891
OK, in order to do that, I had to detach the page from the template. What's a better way to do that? I tried adding an editable region inside the body tag, but DW wouldn't allow that. I tried adding an editable region which contained the body tag, but then DW became unable to display anything in the body of the document.
Anyway, I did detach it from the template and add the onload event to the body tag for selecting the first dropdown and that works. Now I need to get the child dropdown to show as selected. The child dropdown works if the user selects the organization, but if the organization is selected by the onload event, the child dropdown shows as unpopulated and it's not only not selected, it's not selectable.
I tried adding a second onload behavior to populate the child list, but it doesn't do anything, presumably because there's no array selected.
Here's the latest version of my body tag:
<body <? if (isset($_GET['ID'])) { ?> onload="WA_setSelectionsInChildList(MM_findObj('orgID'),<?php echo $row_project['agency']; ?>)" <? } ?> <? if (isset($_GET['ID'])) { ?>onload="WA_FilterAndPopulateSubList(contacts_WAJA,MM_findObj('orgID'),MM_findObj('contact'),1,0,false,': ')" onload="WA_setSelectionsInChildList(MM_findObj('contact'),<?php echo $row_project['contact']; ?>)" <? } ?> >
Perhaps if I tweaked the code on the FilterandPopulateSubList parameters it would work, but since I'm not sure what those parameters refer to, I haven't ventured there.
Thanks, barbara
barbara224891
calendar_add_notemplate.php?ID=81#
This child dropdown is really not working correctly. If the user selects the parent, the child table at first appears to offer the correct choices. However, it's not actually possible to select any of them. When you try to view page source, it doesn't show any items in the child select menu. The parent list is the agency, the child is the contact.
Please help.
The only way to add the onlaod event is to detach the page form the temlate unfortunately.
the onLoad code has some spaces in it that are causing javascript errors:
<body <? if (isset($_GET['ID'])) { ?> onload="WA_setSelectionsInChildList(MM_findObj('or gID'),<?php echo $row_project['agency']; ?>)" <? } ?> <? if (isset($_GET['ID'])) { ?>onload="WA_FilterAndPopulateSubList(contacts_WAJ A,MM_findObj('orgID'),MM_findObj('contact'),1,0,fa lse,': ')" onload="WA_setSelectionsInChildList(MM_findObj('co ntact'),<?php echo $row_project['contact']; ?>)" <? } ?> >
needs to be changed to:
<body <? if (isset($_GET['ID'])) { ?> onload="WA_setSelectionsInChildList(MM_findObj('orgID'),<?php echo $row_project['agency']; ?>)" <? } ?> <? if (isset($_GET['ID'])) { ?>onload="WA_FilterAndPopulateSubList(contacts_WAJA,MM_findObj('orgID'),MM_findObj('contact'),1,0,fa lse,': ')" onload="WA_setSelectionsInChildList(MM_findObj('contact'),<?php echo $row_project['contact']; ?>)" <? } ?> >
barbara224891
That was a good catch. I have fixed the space typos and added some line breaks to make the html lines shorter so they don't get recreated spontaneously, which is how they got there in the first place.
I'm still having 2 problems with this page:
1. If there is a project passed in the URL, the parent field selects properly, but the child dropdown does not populate. If there is no ID passed in the URL, or if the user selects an agency, the child dropdown will populate.
2. When the child dropdown populates, it's not actually possible to select any of the choices. Reviewing the page's source code shows the child dropdown as empty.
I've tinkered a lot, trying different things, so I'm including the body tag here again as it currently stands:
<? if (isset($row_project['agency'])) { ?>onload="WA_FilterAndPopulateSubList(contacts_WAJA,MM_findObj(<? echo $row_project['agency']; ?>),MM_findObj('contact'),1,0,false,': ')"
In trying to understand what's going on, I also made a much simpler page with the essential features I'm working on here. It's at scratch.php?ID=81
With the simpler version, problem 1 still exists, but problem 2 does not. I haven't been able to understand why it allows selection of the child while the real page doesn't.
Thanks, barbara
I think this is caused by having multiple onloads in the body tag.
try using this for the body tag:
<body onload="<? if (isset($_GET['ID'])) { ?> WA_setSelectionsInChildList(MM_findObj('orgID'),<?php echo $row_project['agency']; ?>);<? } ?><? if (isset($row_project['agency'])) { ?>WA_FilterAndPopulateSubList(contacts_WAJA,MM_findObj(<? echo $row_project['agency']; ?>),MM_findObj('contact'),1,0,false,': ');WA_setSelectionsInChildList(MM_findObj('contact'),<?php echo $row_project['contact']; ?>) <? } ?>">
barbara224891
Tried that. Didn't change either problem 1 or problem 2.
Still troubled by the difference between the two pages, the simpler one working slightly better. That might be significant.
OK, I think i see the problem now, the simple page did help, thoug you have one problem on that page.
The child list is named "contactID" on the simple page and "contact" on the other one.
I believe this for the body tag should do the trick:
<body onload="<? if (isset($_GET['ID'])) { ?> WA_setSelectionsInChildList(MM_findObj('orgID'),<?php echo $row_project['agency']; ?>);<? } ?><? if (isset($row_project['agency'])) { ?>WA_FilterAndPopulateSubList(contacts_WAJA,MM_findObj('orgID'),MM_findObj('contact'),1,0,false,': ');WA_setSelectionsInChildList(MM_findObj('contact'),<?php echo $row_project['contact']; ?>) <? } ?>">
