Footer Links Missing
Thread began 10/04/2009 8:39 am by mtterry257743 | Last modified 10/05/2009 5:19 pm by mtterry257743 | 1982 views | 4 replies |
mtterry257743
I'm using DW CS4 and Site Assist Pro 1.0.7 (Texture, Slate) and when I run the wizard, the footer links on the home page are there in design view. But when I preview the page locally or live, the links are missing. I've duplicated the issue several times and this is occuring on more than one site. Any thoughts on this issue?
Thanks,
Matt
Justin Nemeth
Can you provide a link to the page? It's hard to tell without looking at the code of the page. Also, is this happening in all browsers or just certain ones?
-justin
mtterry257743
hendersonoilandpropane.com/
It happens in IE8 and even in compatibility mode.
Thanks.
Justin Nemeth
It looks like the #footer div has 'font-size: 0' and that is what is causing the issue. To fix it, add the following code to your mystyles.css file:
#outerWrapper #footer { font-size: normal; }
-justin
mtterry257743
Thank you very much. But if it's the SA generated page, I wonder why that happened. Anyway, I appreciate it.
-Matt
