Admin Login Page Road Block
Thread begun 10/04/2009 6:02 am by stevenc330599 | Last modified 10/07/2009 12:15 pm by Eric Mittman | 6144 views | 6 replies |
stevenc330599
I see others have had similar issues and I have tried their solutions without success.
I have got PowerCMS installed on a local computer for testing, but I am unable to login to the Admin page, even though I am entering the correct username ('root') and password ('Test'). All PowerCMS files have been put in the directory '/localhost/test/pCMS'.
My 'WA_Globals.php' file looks like this:
$WAGLOBAL_Root_URL = "http://test.co.nz/pCMS"; //Absolute path to your site folder.
$WAGLOBAL_Site_Name = "test";
$WAGLOBAL_localRoot = "/test/pCMS/"; //relative path to your PowerCMS files on your local testing server.
$WAGLOBAL_remoteRoot = "/pCMS/"; //relative path to your PowerCMS files on your remote server.
//iRite Images upload settings
$WAGLOBAL_Images_Folder = "/images/"; //relative path to your images folder.
$WAGLOBAL_Swf_Folder = "/swf/"; //relative path to your swf folder.
// Admin Settings
$WAGLOBAL_Admin_UserName = "root";
$WAGLOBAL_Admin_Password = "Test";
and my 'localhost.php' file looks like:
# FileName="Connection_php_mysql.htm"
# Type="MYSQL"
# HTTP="true"
$hostname_localhost = "localhost";
$database_localhost = "test";
$username_localhost = "root";
$password_localhost = "Test";
$localhost = mysql_pconnect($hostname_localhost, $username_localhost, $password_localhost) or trigger_error(mysql_error(),E_USER_ERROR);?>
Could somebody please advise as to what am I doing wrong?
Thanks,
Steven.
This is usually just a path issue or not entering the details correctly. It looks like the settings you have specified here should work. The paths for the images and swf should not have the slash in front of them but they should not affect the login.
What is in the URL when you attempt to login to the Admin?
stevenc330599
I type the following in as the URL:
'http://localhost/test/pCMS/admin/index.php'
then the address bar in IE (7) becomes:
'http://localhost/test/pCMS/admin/users_login.php?accesscheck=%2Ftest%2FpCMS%2Fadmin%2Findex.php'
and the Login page displays correctly with all images and css styles. When I enter the correct user name/password pair the page just refreshes.
Steven.
The access check variable that is shown in the URL indicates that access was denied when you attempted to visit the index page. If you were entering the username incorrectly then the page should just refresh without anything in the URL. This tells me that you are failing the Administrator rule that is applied to the index page. The only thing this rule does is check the password you entered versus the password in the globals file. If you are failing this rule it indicates that the password you are entering is not correct.
As a quick test of the password go into the login page and go to line 50, add in two new lines and put this code in those two lines:
The value of the entered password is: <?php echo isset($_SESSION["AdminLogin"])?$_SESSION["AdminLogin"]: ""?><br/>
The value of the global password is: <?php echo $WAGLOBAL_Admin_Password ?>
After putting this in place and saving the page test it out. When you attempt to login and are taken back to this page it should list the password you entered and the value from the globals file for you to compare against.
This should get you going on the rite track, keep in mind that whatever your password is in the globals file will be listed here on your admin login page so this should only be done as a test, you should not leave this in place on a live site.
stevenc330599
When I enter your code I get:
The value of the global password is: Test
When I change your code by substituting "Password" for "AdminLogin" I got:
The value of the entered password is: Test
The first time, when I re-entered the information I got:
This leaves me completely confused!
Steven.
stevenc330599
More on the code
Further testing has revealed that when I enter the correct admin user name the password is set to blank. When I make a mistake with the admin user name the password (the correct, or a wrong one) is displayed by your script.
It looks like there is something wrong with the script called by the form element. Presumably lines 7 to 10 of the same page .........
The confusion just deepens!
I have submitted a ticket for you on this issue so that we can exchange files. Please login and visit your support history to update the ticket.
