Problem with upgrade 4.5.1
Thread begun 10/03/2009 8:24 pm by dcb286193 | Last modified 10/05/2009 2:25 pm by dcb286193 | 2039 views | 2 replies |
dcb286193
I upgraded to 4.5.1 by deleting the extension then adding the new extension. Opened dream weaver cs3 on mac ver 10.4.11, made a change to the cart, now the page will not load. If I delete all the cart information from the page it will load. As soon as I apply any cart application to the page, the page will not load.
Any help is appreciated.
Add the following to line 1 of your page to see if therte are any PHP errors occuring:
error_reporting
(E_ALL);
report back any errors that are being displayed, also compress the problem page into a zip file and send it along with your reply sop I can examine the code.
dcb286193
After adding the code you indicated I was able to trace the problem. On the upgrade I added a column to the full description area and did not add it in properly. Problem solved everything working OK now.
Thanks for the help.
