retrieving record number from a DW recordset
Thread begun 10/03/2009 7:13 am by CraigR | Last modified 10/04/2009 3:04 am by CraigR | 3475 views | 4 replies |
CraigRBeta Tester
when i use dreamweaver to bind a new recordset and test the sql statement, in the displayed results, as well as the data, you get the record number displayed.
i want to be able to retrieve this record number to use elsewhere, can anyone tell me what syntax i need to retrieve it?
Dave BuchholzBeta Tester
Craig,
do you mean the id number from the database or the position of the record in the recordset ?
CraigRBeta Tester
Hi Dave.
i mean the position (row number) of the record in the recordset.
i'm sure i did this using mysqli, but the syntax is different when the rs is created within DW.
This is what I use in DW to do this Auto Numbered Records with a DW Recordset
CraigRBeta Tester
Thanks Dave.
that certainly works when displaying the recrord number in my repeat region.
i'll see if i can use this approach in solving my problem
