Site Import does not work V3 it freezes
Thread began 10/03/2009 3:30 am by David308620 | Last modified 10/07/2009 1:36 pm by Jimmy Wu | 2343 views | 5 replies |
David308620
I had site assistant 2 and had problems with it so I upgraded to V3 and installed it with extension manager without removing V2. When I tried to import a site after I had put in the URL etc and clicked finish it just sat and did nothing the progress bar does not move and the program has frozen and I can't get into it without doing a restart of the computer, by the way I am using Dreamweaver CS3.
I then removed V3 from extension manager and then reinstalled it but it still does the same thing. Hopefully I willget an answer to solve this problem as I need to import urgently.
Kind regards
David
Jimmy Wu
What site are you trying to import? Also do you have any security software installed on your machine?
mstruthers9080Beta Tester
Hello,
I've tried a few different sites but can't open the program owing to the error message. Yes, I do have security software installed. I use Norton.
Sorry - I've inadvertently replied to the wrong thread.
David308620
Yes I do I have "Avg"," windows defender" and Malwarebytes installed the site I am trying to install is "http://luxurypropertyinlamanga.com" but I have tried other sites with the same results I am using Windows Vista. This morning I installed CS3 on my laptop which has XP on it and I am getting the same result when I try Site Import 3.03
My laptop does not have any antivirus software and I added all the cs3 programs to exceptions in the windows firewall. By the way I am based in Spain so I am nine hours ahead of you. Should I call you and try to solve this over the phone to shortcut the problem?
Kind regards
David
Jimmy Wu
Did you have any previously working versions installed?
Did you get any error messages when you are running the extension?
You're working with Site Import, right? You mentions Site Assistant in your first post, and I just wanted to make sure you weren't referring to another extension.
