Sum TotalWeight at Checkout
Thread begun 10/02/2009 8:22 pm by ninetyplus | Last modified 11/30/2009 4:45 pm by ryanteets270615 | 8015 views | 10 replies |
ninetyplus
I've implemented a way for my customer to choose different weights of roasted coffee (1lb, 2lb and 5lb bags) through a menu/list then select the quantity of each item. I've made the weight value unique in the eCart column but when I bind the TotalWeight value to the checkout page to show the total weight of all orders, the value that appears is from the first item in the cart. For example, If I have two 5lb bags of coffee A, one 2lb bag of Coffee A and three 5lb bags of Coffee B, the TotalWeight will only show the sum of the first item in the cart which is coffee A (10lbs). Is there a calculation that I can create to sum up all of the weight values? I'm using PHP.
Thanks!
Steve
In order to get the subtotal for the entire column you will need to use the binding within the TotalColumn function like this:
$WA_Store_Cart->TotalColumn("TotalWeight")
Just use this in place of where you are just using TotalWeight, you may need to update the name of the cart object to your own.
rob_wilkins385013
Same issue here. can you please be more specific?
exactly where and in which file would I place that code. Sorry to be a pain, but this would be a great help. Im not really sure how to 'bind' something.
Thanks.
The original user was mentioning that he put the binding for the total weight on the cart display page to display the total weight. The problem was that this will only display the total weight for the first item in the cart, to get all of the items weight you would use the total column around it like the example code.
You would use this anywhere that you would like to have the total weight of the entire cart and not just the first item in the cart. The update would be make in the code view, you can just wrap the function around the total weight value you already have.
Kevin373660
Total Shipping Weight Function
I am using 4.5.2 with php and MySQL.
I do not seem to have a math "fuction" that Eric mentioned, on any of may eCart generated pages to calulate the combined TotalWeight for all the items in the cart. I can echo the value on the page and it only displays the weight of the first item. I am shipping with UPS with automatic rate lookup. The rate returns correct for the TotalWeight value which is bound to their configuration setting.
Does anyone have a copy of the code block that adds the weights of all the items that are in the cart and the code (mentioned in this post) to assign its value the the TotalWeight cart->DispalyInfo("TotalWeight")???
In eCart the column that holds the total weight for a single item is called TotalWeight. Each item in the cart will have a value for this binding. If you would like to have the combined total weight of the entire cart you would just use the total column function like this:
You would of course need to update this to be the name of your cart. If this is not what you are looking for please explain a little more about what you are trying to accomplish.
Kevin373660
This post has been deleted.
Kevin373660
Ok, I got it to echo the value on the cart page and I assume that you could remove the echo part, with the following code:
<?php echo ($MyCartName->TotalColumn("TotalWeight")); ?>
THEN on the confirm page changed the code for the shipper to:
$Shipping_PackageArray[$Shipping_PackageIndex]["PackageWeight"] = "".$MyCartName->TotalColumn("TotalWeight") ."";
This will total all of the item weights if shipping in one box. I used an average size of shipping box as most costs are mainly factored by weight.
Kevin373660
For digial goods, Zero combined shipping weight = no cost
For the benifit of others in the formum that may need this.
In my table I have defined the weight value for each item. If the item/product does not require shipping the weight value is set to =0 (zero).
However, when testing with a single item that has a zero weight value, the base rate for a minimum 1lb box is returned.
************* confirm.php - by pass the UPS if weight is 0 (zero) *************
if ($_SERVER["REQUEST_METHOD"] == "POST" && $ClubCartUSA->TotalColumn("TotalWeight") > 0) {
Additional work is required to both the checkout and confirm pages to hide the shipping sections. I just havn't got that far yet.
Nice work with the conditional shipping server behavior. When it comes to the checkout page and confirm pages you can use your same logic to only show these parts when there is a weight in the cart. If you have server validations occurring for the shipping info from the checkout page then you can use your if statement to prevent these from occurring if there is no weight.
