refreshui problem with Surveyor
Thread began 10/02/2009 6:48 pm by joel353662 | Last modified 10/06/2009 11:46 am by Eric Mittman | 2197 views | 3 replies |
joel353662
While executing onResize in WA_SiteTools_Progress.htm, the following JavaScript error(s) occured: In file "WA_SiteTools_Progress": refreshUl is not defined.
I keep getting the above error when trying to use Surveyor. I saw the recommendation to delete the cach.dat file in my configuration folder- did that, restarted and still no luck...
I am on Mac OSX 10.5.8
Any advice, help ideas will be greatly appreciated!!
UPDATE: Just noticed I now can't start any web assist extensions from the Site dropdown in my Dreamweaver cs4... several javascript errors are mentioned nbut all seem to revlove around a refreshui...
This seems like it may be a corruption of the configuration folder of some type that is causing the problem. You should try deleting the configuration folder and reinstall the extension to see if you can get past the issue. Here are some instructions for clearing out the configuration folder.
showpost.php?p=12293&postcount=2
joel353662
Problem solved
Uninstalling and reinstalling the extension solved the problem.
Excellent, that is good news. Let us know if you have any other issues or questions.
