CSS Sculptor 3 remove a design
Thread begun 10/02/2009 3:47 pm by reg.phipps388482 | Last modified 4/12/2010 11:10 pm by Douglas.DeAvila403969 | 3200 views | 4 replies |
reg.phipps388482
I made changes to 1 Column Fixed, Centered design type and saved it with a design name of NewsRed. I then made more changes and accidently changed the name to NewsRed2. Now when I select a 1 Column Fixed, Centered design type I see the default designs i.e. Cabo Sunset, Deep Jungle etc plus the two new designs NewsRed and NewsRed2. I now realise I should have save the changes as a design type not a design. How can I remove the design NewsRed and NewsRed2 from the design type 1 Column Fixed, Centered?
CSS Sculptor will only allow you to Save a Design, not a design type. When you clicked the edit CSS Button, you are editing the css design, when it is saved, the only option presented to you is to save it as a design.
reg.phipps388482
OK but when you save a preset you can fill in two names a Desing Type and a Design. When I type in a new Desing Type name it fills in the Name field with 'New Design' which you can either accept or overwrite. After it's saved I can then make changes and saved with a new Design name leaving the Design Type name as is. Preset Manager shows this Desing Type name which can be selected. Once selected the funtionality Edit, Remove, Export or Import can be selected. If Remove is seelcted then next time I use CSS SCULPTOR it is not in the 'Choose a design type' list. As I said unfotunately I saved the installed preset of '1 Column Fixed, Centered' with two new design names and unless I use the Preset Manager to delete this Design Type '1 Column Fixed, Centered' which I don't want to do because it will remove the installed Desing Type and will not be availabe in CSS Sculptor I don't know how to get rid of the extra design name in this installed type. Is there some where the design name associated with a design type is held. If I remove and the reinstall CSS SCULPTOR will it get me back to '1 Column Fixed, Centered' without the new desing names i.e. only the installed ones.
Yes, if you Uninstall CSS Sculptor 3, then install it again, it will revert back to the original set of designs.
Remove design type...
Is this the only way to remove a design type? Uninstall and install CSS Sculptor?
Thanks!
Douglas
PS. I posted a separate thread for this not realizing there was this one...my apologies...
