Javascript error when using QueryBuilder
Thread begun 10/02/2009 7:54 am by info154735 | Last modified 10/05/2009 1:36 pm by Jason Byrnes | 3652 views | 4 replies |
info154735
Hello,
I installed several extensions. They all work fine. Except QueryBuilder. I registrated succesful but when I want too use this extension I get this error: At line 746 of file "C:\Program Files\Adobe\Adobe Dreamweaver CS4\Configuration\Shared\Controls\Scripts\WATrigger.js":WA_getDocumentDom is not defined
I reinstalled the extension but it didn't help.
Has anyone a solution for this?
Do you have eCart 4.5.0 installed?
If so, uninstall it from the Extension Manager and Install version 4.5.1 which is available for download from the Download center.
If not please post back letting us know which extensions are installed, include the version numbers.
info154735
Hello Jason,
Thank's for your fast reply. I have installed eCart 4.5.1 as wel all of my extensions from WA are the most recent versions.
Do you have DataAssist version 2 installed?
Did you install eCart 4.5.1 after DataAssist 2?
please send a screen shot of your extension manager screen showing version numbers so I can see what is installed.
Probably best to add the screen shot to a zip file so it will be large enough for me to see anything.
Query builder is a very old extesnion that has been discontinued and is not compatible with Dreamweaver CS4.
The version of Query Builder you have installed, 2.5.5, was released in 3/2005.
In 5/2005 it was upgraded to Database Search.
in 10/2007, DataAssist 2 was released which included Database search.
The latest version of Dreamweaver that you could use Query Builder in would me Dreamweaver MX 2004.
You would need to upgrade to DataAssist 2 to get the same functionality in Dreamweaver CS4.
