Contact Form - Autoreply
Thread begun 10/02/2009 5:43 am by todd368532 | Last modified 1/12/2010 10:54 am by Eric Mittman | 5760 views | 5 replies |
todd368532
Hi Gang,
I use the Contact From Solution Pack and would like to have an autoreply sent to the sender of the form. It would just be a "Hey we got your email, thanks, we'll get back to you" kind of thing. How/where do I add that?
Todd
There are a couple of ways you can do this. The easiest is probably to just duplicate the email code and use the email address that the user entered like this:
$RecipientEmail = "".($WAGLOBAL_Contact_Email_To)  ."";include("WA_Universal_Email/WAUE_contact_1.php");
   $RecipientEmail = "".(isset($_POST["Email_address"]))?$_POST["Email_address"]:"")  ."";include("WA_Universal_Email/WAUE_contact_1.php");
This will just send a duplicate of the message to the user. Another more complex way would be to duplicate the UE code then update the values to use a copy of the email page. You can then go into the copy of the email template and change the body to whatever you would like. This is a more advanced technique that requires coding and editing.
The other way to do this is to just use Universal Email to add a new server behavior to the contact page. You can just craft the message to be whatever you would like and send it to the posted email address:
isset($_POST["Email_address"])?$_POST["Email_address"]:""
Wasntme
error
I added the code as advised, it works with one error. I gets 2 emails instead of one.
Please help...
Do you only get the two emails when you have the extra line of code on the page? When you added the extra code to the page did you add both lines in addition to the code that was already on the page or did you replace the one line with the two lines of code?
The first line of that sample code should already be in place on your page. If you just added the two new lines of code then you would ge the email twice because the code would execute twice. Please post back with the details so we can look into this further.
Wasntme
Thank you
Thank you Eric you were correct i had 1 extra line of code.. how stupid of me. thank you so much for your help.
You are very welcome, I'm glad you got it sorted out.
