Menu Expanding behind Flash File
Thread begun 10/01/2009 3:29 pm by kphillips162496 | Last modified 8/15/2025 12:23 am by anonymous | 2890 views | 4 replies |
kphillips162496
I did read a post for this in Jan of 09, and did put in the z-index for the TopNav Div and the Flash Div but the menu continues to fall behind the flash file.
Here is the temp site. index.php
This is using the Home.css
Any help would be greatly appreciated.
I have seen this type of behavior in sites that use Flash before. The fix is usually two part, the first part is to adjust any css and z-index that may affect this. It sounds like you have adjusted the z-index but you should check the positioning of the divs. If they do not have the same positioning the z-index will not work out properly.
The other thing that is the major cause of this is not have the wmode property set properly. Setting the wmode parameter to have a value of transparent should make it behave correctly. This has been the problem in most of the cases where I have seen this issue. There is a lot of info about this setting around on the web.
kphillips162496
That was the issue. Need the transparent and the z-index set and it works. Thank you.
Great to hear. This is a common issue when using Flash media on pages, but not adjusting the z-index can have the same effect so it is good to check both.
anonymous
It sounds like the Flash object might need the wmode parameter set to transparent or opaque. That usually fixes menu overlap issues even when z-index is set.
