Error while trying to create
Thread begun 10/01/2009 10:53 am by roxcastaneda251760 | Last modified 10/02/2009 1:39 pm by roxcastaneda251760 | 3850 views | 4 replies |
roxcastaneda251760Beta Tester
I get 2 error windows:
1.- While executing onResize in WA_SiteTools_Progress.htm, the following JavaScript error(s) occurred:
In file "WA_SiteTools_Progress"
refresh UI is not defined
2.- Error generating menu (wa.generating.menu):
TypeError: MM.WA_createProcessingObject is not a function
I have already tried removing the extension and afterwards installing it again. These errors continue to appear
Please help urgent!
maurizio.melandri390100
Same Problem
I had the same problem, I tried to install everything again, now I have this error "while executing onLoadin wamw_serial.htm, the following JavaScript error(s) occured:
At line 214 on file "C:\Programmi\Adobe\Adobe Dreamweaver CS4\Configuration\Shared\WebAssist\CSSMenuWriter\Library\Shared_Ser_Mactivation.js":document.formLayer.document has no properties
This problem for all extension :(
Dani Chankhour
Deleting your cache should clear the error that you are receiving. Here is the instructions:
146/
everything worked. Thank
this works!
This works fine:
See this PDF for more info on removing the cache file:
technote...ion_issues.pdf
