Redirect does not work!
Thread begun 10/01/2009 10:44 am by Cologne | Last modified 10/09/2009 11:46 am by Cologne | 5481 views | 6 replies |
Cologne
the WA Server Redirect does not work!
<?php require_once("../../WA_DigitalFilePro/HelperPHP.php"); ?>
// WA_UploadResult1 Params Start
$WA_UploadResult1_Params = array();
// WA_UploadResult1_1 Start
$WA_UploadResult1_Params["WA_UploadResult1_1"] = array(
'UploadFolder' => "Images/",
'FileName' => "[FileName]",
'DefaultFileName' => "",
'ResizeType' => "2",
'ResizeWidth' => "400",
'ResizeHeight' => "0",
'ResizeFillColor' => "" );
// WA_UploadResult1_1 End
// WA_UploadResult1 Params End
WA_DFP_SetupUploadStatusStruct("WA_UploadResult1");
if(isset($_POST["button"])){
WA_DFP_UploadFiles("WA_UploadResult1", "image", "0", "", "JPG:80", $WA_UploadResult1_Params);
if($WA_DFP_UploadStatus["WA_UploadResult1"]["statusCode"] == 1){
$WA_Redirect_URL = "Test/Upload/Upload2.php";
$WA_Redirect_KeepQS = false;
if ($WA_Redirect_URL != "") {
if ($WA_Redirect_KeepQS && $WA_Redirect_URL != "" && isset($_SERVER["QUERY_STRING"]) && $_SERVER["QUERY_STRING"] !== "") {
$WA_Redirect_URL .= ((strpos($WA_Redirect_URL, '?') === false)?"?":"&").$_SERVER["QUERY_STRING"];
header("Location: ".$WA_Redirect_URL);
<head>
<title>Upload</title>
</head>
<body>
<form action="" method="post" enctype="multipart/form-data" name="formUpload" id="formUpload">
<p>Bild:
<input type="file" name="image" id="image" />
</p>
<p>
<input type="submit" name="button" id="button" value="Bild hochladen!" />
</p>
</form>
</body>
</html>
My redirection is: $WA_Redirect_URL = "Test/Upload/Upload2.php";
But when it comes to the redirection the browser goes to: Test/Upload/Test/Upload/Upload2.php
The adresse doubles!!!
Please fix that error.
Denis
is the upload page in the test/upload folder?
Upload.php
If that is the case, then set the redirect to:
$WA_Redirect_URL = "Upload2.php";
The redirect is a relative link. If the two pages are in the same directory, there is no need to add the folder information.
Cologne
Hi Jason,
I dont do it manually. I choose the page with the folder button, nothing else.
Upload1.php is the upload page. and both are in the same folders: Test/Upload/
So there must be an error in the WA Server Redirect, cause I picked it with the folderbutton :-)
The thing is, when I hit the button it starts in the root folder. maybe thats the error.
Denis
Cologne
it seems the FILE-PICKEr doesn not work right. now I see that its always taken from the ROOT.
thats not so good :-(
Cologne
Jason,
is it on the LIST to be fixed?
I have created a support ticket so we can look into this.
Cologne
Oh Hi Jason,
you can close the ticket, I gonna change manually.
thanks for the ticket,
Denis
