Image not appearing in the results or detail page
Thread begun 10/01/2009 8:36 am by tyler815351411 | Last modified 10/01/2009 3:58 pm by Jason Byrnes | 2133 views | 1 replies |
tyler815351411
Using digital pro and adding to my insert and update pages the image upload into the correct folder. In my database it shows the filename but should it show the full url of the image in the database, as when I update the database manually with the full url the image then works properly.
How do I get the image to show on the result and detail page?
or get the full url of the image in my database?
In the database, it should only be storing the image name.
To display the image on your page, you need to prepend the relative path to the folder the image is uploaded to src attribute of the image tag.
For example, if the image is uploaded to images and the results page is at results.php
the image source should be:
<img src="images/<?php echo $row_Recordset['imageColumn']; ?>" />
