Universal Email 3.06 crashes CS4 when applied to a page created with CSS Form Creator
As stated above. I applied a form using CSS Form Creator and that went in fine. Attempting to add Universal Email crashes CS4.
Screenshot attached.
I have tried to reproduce the problem you are having and have not been able to. This may be an issue with DW in the cache file or the config folder. Here is a link to some troubleshooting techniques that may help you get past this issue:
146/
Please try the steps listed here for deleting the cache file and if that does not work try removing the config folder. Let us know if you continue to experience any issues after this.
