"sucess at last"
Thread began 9/30/2009 2:17 pm by mehd389652 | Last modified 9/30/2009 4:04 pm by mehd389652 | 1686 views | 2 replies |
mehd389652
"sucess at last"
Jason !!!
You need to check your copy of "Power CMS"
the one that newbies like me download at the
webassist.com site because I seriously just loaded
a new copy of this onto my machine thinking it
was my mistake and it is in your script.
To fix it I went to my CMS100 folder then to
my Connections folder then I opened up my localhost.php
file then find the line that ends in E_USER_ERROR);
put your cursor right at the end of the semicolon and press
the delete button until the closing delimiter (?>) comes to
the cursor and then press the return key once then put
your cursor at the end of the delimiter (?>) and hold down
the delete button for a few seconds to make sure there
are no spaces there.
Save the file.
And then like magic it works.
So it is in the original script. I can't believe more people
haven't had the same problem ??? and that something that
simple could cause such a hassle.
So now I'm ready to work on the next bug in the program which
is this message:
Warning: strpos() [function.strpos]: Empty delimiter. in /home/pythoni/public_html/CMS100/CSSMenuWriter/cssmw/menu.php on line 6
Now that I am in my admin section this is the message
that is viewed at the top of the screen?
How do I solve that one ???
I'll take a look at the connection file.
The error you are getting sounds like the WA_Globals are not properly set. See my reply to the other thread you started about this error:
showthread.php?t=4958
mehd389652
Yes it was that too
But the main offender was the connect file
Ciao,
Mike
