Connecting to a Remote Host who uses PHPMyAdmin
Thread begun 9/30/2009 1:27 pm by karen.marley367377 | Last modified 10/23/2009 3:51 am by karen.marley367377 | 6381 views | 5 replies |
karen.marley367377
I have a remote host who uses phpmyadmin.
How do I create a connection string in my php pages to connect (I have all the relevant remote host, username and password), to connect to the host?
Office-172461
You could use somethings like this:
$hostname_conn = "localhost";
$database_conn = "databasename";
$username_conn = "username";
$password_conn = "password";
$conn = mysql_pconnect($hostname_conn, $username_conn, $password_conn) or trigger_error(mysql_error(),E_USER_ERROR);
Replace the italics with your own info. It really doesn't matter what program the host uses to view the database.
More info here:
function.mysql-pconnect
karen.marley367377
Connecting to Remove Host
Thank you for your help. Would this be on each php page or in singularly in the connections php, for example : connections/mysql.php
Office Guy-172461
You only need to connect once.
neil186288
Create a php document and put code in it:
# FileName="Connection_php_mysql.htm"
# Type="MYSQL"
# HTTP="true"
$hostname_bgweb = "localhost";
$database_bgweb = "database name";
$username_bgweb = "database user name";
$password_bgweb = "database password";
$bgweb = mysql_pconnect($hostname_bgweb, $username_bgweb, $password_bgweb) or trigger_error(mysql_error(),E_USER_ERROR);
Just that text, nothing else.
Save this as (say) connect.php in a folder called Connections
Then at the beginning (first line) of any php page that needs to make a connection to your mySql database put the line:
<?php require_once('Connections/connect.php'); ?> (or whatever the path would be in relation to your page)
This is neater and easier in the long run, - DreamWeaver for example will look in the 'Connections' folder to see if you have a connection already set up, and will use it automatically as an option if ever you are creating code that requires calling on your mySql database.
karen.marley367377
