Lost edit Function
Thread begun 9/29/2009 5:12 pm by dan377928 | Last modified 9/30/2009 10:29 pm by PeterL | 2572 views | 3 replies |
dan377928
Lost edit Function
I created a new menu and cannot seem to edit the menu again. I have other sites when you click on a menu you get edit contents button. That is not there on a new site I am building
PeterL
HTML users will need to select the script icon beside the menu.....is said in the user manual.
But indeed, it is gone in the newest version of menu_writer??
Peter
Neil Beadle
Edit button not displaying
This is actually documented in two locations within the CSS Menu Writer Documentation.
Check out the FAQ titled "Why does the Edit button not display in the Properties Inspector?"
css-menu-writer/
Also, on the 'Creating a new CSS Menu Writer Menu' page within the Help Documentation
mw_01.htm
...there is the following note:
Note: If you working with HTML pages, Dreamweaver must have Scripts set to display under Invisible Elements. You will then select this script icon beside your menu to display the CSS Menu Writer Properties inspector.
* Edit > Preferences.
* Select Invisible Elements from the Category column.
* Make sure Scripts is checked.
* Click OK.
PeterL
of course!!
Thankyou Neil.
Peter
