What does this error message mean
Thread begun 9/29/2009 11:48 am by Roxana | Last modified 11/17/2009 7:40 am by kevin347925 | 2996 views | 4 replies |
Roxana
Error in server behavior eCart Object: the participant's property is not an array, or the elements in the array are not nodes in the document.
Roxana
This was followed more error messages:
Error in server behaviour Add To Cart Button: the participant's property is not an array, or the elements in the array ar not nodes in the document.
Error in server behaviour Create Dynamic Array: the participant's property is not an array, or the elements in the array ar not nodes in the document.
What version of eCart do you have installed?
Make sure you have version 4.5.1 installed. If you have a previous version, please remove it form the Extension Manager, then download and install version 4.5.1.
After installing version 4.5.1, and before launching Dreamweaver, delette the Dreamweaver Cache file from the users configuration folder:
Roxana
Hi Jason,
Thank you for your reply. I had version 4.5.0 installed. I followed the instructions how to install the new version. I will let you know, if the error messages come up again.
kevin347925
Same trouble
I am getting this same problem with 4.5.2 installed.
