Javascript error when trying to set up new password page!!
Thread begun 9/29/2009 6:53 am by Banksie | Last modified 10/06/2009 5:41 pm by madelectrical386948 | 6974 views | 12 replies |
Banksie
Am getting the following error when using WA Security Assist to generate a new password (similar to the process described in the on-line video tutorial).
On selection of Server Behaviors > WA Cookies Toolkit > Set Session Value I get:-
"JavaScript error while loading WA eCart 01Session.htm:
At line 746 of file "C:\Program Files\Adobe\Adobe Dreamweaver CS4\Configuration\Shared\Controls\Scripts\WATrigger.js": WA_getDocumentDOM is not defined"
Please don't say it's another corruption of my DWCS4 configuration file and that it needs to be deleted as with previous times following upgrading some of my WA extensions. That takes the best part of half a day to remove the reinstall all extensions etc.!!!!
jenkolaka19379118
Me Too
I am getting the exact same problem since I upgraded the dot release. I am using dreamweaver cs3
I have crated tickets for both of you so We can look into the cause of this problem.
To view and edit your support tickets, log into the Support History page:
supporthistory.php?
madelectrical386948
awwwww,
I was hoping there was an answer here Jason. I am having the same problem.
thx
Mike D
jenkolaka19379118
Hi Mike,
The problem came from ecart for some reason. Once I installed the ecart dot release (the update version) it fixed that error.
madelectrical386948
Awesome, I will give that a try.
Thx jenkolaka
Mike
David CHnet.com
With all the different extension upgrades all the time I find that I reguarly have problems with one extension afetr installing another, and I am always careful to only install the "newer" versions of files.
The solution seems to mostly be one of two things ...
- quit DW, empty cache, restart DW, try again
- uninstall offending product, reinstall
and sometimes ...
- uninstall and reinstall eCart, which seems to walk over everything
David CHnet.com
Ironic
Ironically I have just been hit by exactly the same JavaScript error.
- uninstalled eCart
- wait 55 mins (thank you Adobe for making the extension manager so swift)
- tried again - all OK
Moral of this tale for me is not to install eCart. I never use it (it came bundled) and I only install it because I own it. All I ever seem to do with it is uninstall/install when I have issues with WA product/code versions. And as we all know, that takes an age ...
There is no reason to install an extesnion if you dont use it. I recommend only installing extensions that you are going to use, when you launch Dreamweaver, it will look for any extensions that you have installed to create menus for them which will increase the load time. Installing extensions you dont use will only increase the time it takes Dreamweaver to load.
David CHnet.com
Installations
Many thanks, Jason!
