Error code
Thread begun 9/28/2009 10:44 pm by J7HNW | Last modified 9/30/2009 2:01 pm by Eric Mittman | 3504 views | 3 replies |
J7HNW
Error code
Please help. I am getting this error. I have checked all mail server settings are correct.
error '80040211'
/WA_Universal_Email/CDOSYS_VB.asp, line 149
Url: members.asp
I have attached the file zipped.
John
If you can confirm that the mail server settings are correct this error may be associated with the mail object itself. Do you know that this object has been registered on your server properly? If not you will need to check with your server admin to ensure that it is. With the object properly registered and the mail server settings correctly inputed it should send the emails.
J7HNW
Universal e mail
Hi Eric
This was working on another form on the site a couple of days back so I assume it is registered properly. I am using Cdosys as on all other sites on the same server.
I have uninstalled and retired 3 times but keep getting this error
error '80040211'
Any more ideas ?
John
Would it be possible for you to perform a test with any of the other instances of CDOSYS? If you can please try using one of your other CDOSYS based scripts to send an email to the same individual and also use the same settings. Using the same settings and email address are important to help exclude these values as a possible source of the problem.
This will help to indicate where the problem may be, if you are successful with the same settings and details but in a different script on the same server then it would indicate a problem with this specific implementation. Otherwise it would indicate a problem with the object or settings. Please give this a try and let us know what you discover.
