Can't run the Windows SQL tutuoria
Thread begun 9/28/2009 6:13 pm by dconnerusa | Last modified 9/28/2009 6:39 pm by neil186288 | 2092 views | 2 replies |
dconnerusa
I cannot establish my data source in Dreamweaver CS# with MySQL. I have downloaded the Database starter kit, but when I start the tutorial, there is an error message that says "Adobe Flash Player has stopped a potentially unsafe operation. The following local application on your computer network:(gives the path to the same directory)
To let this application communicate with the Internet, click settings, . . .
When I click settings I configure the Flash player to let anything from [url]www.webassist.com[/url> get through, but I continue to get the same error and I cannot play the MySQL setup for Windows. Can you give me the path for that tutorial on your site so I can just go play it without screwing with the Flash player interface in the starter kit?
David Conner
Office-172461
When you get the security warning, it should give you the path to the file that triggered the warning. It is usually is a local path. Flash is worried about a Flash app trying to access other resources. I usually go up a couple folders and add it as trusted so I don't have to change the settings for each file.
neil186288
Hiya D,
This is a good link for showing what to do:
4c093f20.html
