RetVal Coldfusion error
Thread began 9/28/2009 4:01 pm by syorke316463 | Last modified 11/03/2009 12:40 pm by Jason Byrnes | 2863 views | 3 replies |
syorke316463
I had successfully implemented a coldfusion ecart implementation/solution and went through several sandbox tests and everything seemed to work fine. Suddenly I've gotten the following error from coldfusion:
Complex object types cannot be converted to simple values.
The expression has requested a variable or an intermediate expression result as a simple value, however, the result cannot be converted to a simple value. Simple values are strings, numbers, boolean values, and date/time values. Queries, arrays, and COM objects are examples of complex values.
The most likely cause of the error is that you are trying to use a complex value as a simple one. For example, you might be trying to use a query variable in a <CFIF> tag. This was possible in ColdFusion 2.0 but creates an error in later versions.
The error occurred in C:\Inetpub\wwwroot\NewEvents\WA_eCart\Adv_CO_Scripts\PP_DirectPayment_CF.cfm: line 293
Called from C:\Inetpub\wwwroot\NewEvents\confirm1.cfm: line 271
Called from C:\Inetpub\wwwroot\NewEvents\confirm1.cfm: line 267
Called from C:\Inetpub\wwwroot\NewEvents\confirm1.cfm: line 1
291 : </cfif>
292 : </cfif>
293 : <cfset retVal = Trim(retVal)>
294 : <cfreturn retVal>
295 : </cffunction>
Can anyone help, I don't see anything in the forums on this.
I'll need to examine your cofirm1.cfm file to look into the issue. I have created a support ticket so that you can send this file to me privately, to view and edit your support ticket, log into your support history:
supporthistory.php?
avishek.bhattarai392828
I have an error as listed below, I saw many references to errors like this but could not resolve. Please help.
The expression has requested a variable or an intermediate expression result as a simple value. However, the result cannot be converted to a simple value. Simple values are strings, numbers, boolean values, and date/time values. Queries, arrays, and COM objects are examples of complex values.
The most likely cause of the error is that you tried to use a complex value as a simple one. For example, you tried to use a query variable in a cfif tag.
The error occurred in /usr/home/phrma2/usr/local/etc/httpd/htdocs/pap-dms/programs/frm_program.cfm: line 766
Called from /usr/home/phrma2/usr/local/etc/httpd/htdocs/pap-dms/programs/frm_program.cfm: line 1
Called from /usr/home/phrma2/usr/local/etc/httpd/htdocs/pap-dms/programs/index.cfm: line 26
Called from /usr/home/phrma2/usr/local/etc/httpd/htdocs/pap-dms/index.cfm: line 26
764 : <tr>
765 : <td valign="top">Program URL</td>
766 : <td valign="top"><input type="text" name="url" size="60" maxlength="100" value="#url#" onBlur="validateURL(this)"></td>
767 : </tr>
768 :
Please compress you frm_program.cfm and index.cfm files into a zip archive and attach them to your response sop I can take a look at the code.
