Extension Manager says files are in use
Thread begun 9/26/2009 4:55 pm by neo314 | Last modified 10/24/2009 8:28 pm by neo314 | 7808 views | 11 replies |
neo314
During this last round of updates I keep encountering the same problem. I cannot uninstall and reinstall nor can I install over the old version of several extensions because I keep getting messages that certain files are in use. The files keep changing. I have deleted the cache. I have seen this before, but I cannot seem to get around it this time at all.
The in use files seem to primarily be in C:\Users\[USER_NAME]\AppData\Roaming\Adobe\Dreamweaver 9\Configuration\Shared\WebAssist\ApplicationBuilder... Sometimes in images sometimes in library.
Any idea how to get around this consistently?
office172461
Did you make sure Dreamweaver is closed while installing extensions?
neo314
Yes. I also checked the task manager to be sure the process was not running. I also have tried shutting down and restarting the extension manager.
office172461
If you don't have any older versions of DW installed, I would say your configuration folder might be corrupt.
neo314
I don't think so. Something is telling the extension manager that the file is in use.
office172461
From Adobe:
"If Dreamweaver starts behaving unpredictably, this sometimes indicates a corrupt user configuration folder."
I would say something is wrong when files are left open in the configuration folder. I went through all of the updates, with no issues so I don't think it's a problem with the updates.
Maybe something here will help:
Solving problems with Dreamweaver
146/
neo314
Can you elaborate on that. It may help me solve the problem. If Dreamweaver is not running, how can files "be left open in the configuration folder?"
What does that mean is no program is using them. It is a huge deal to wipe the cofiguration folder and start over. I have a lot installed above and beyond the many WA extensions.
office172461
The way it normally works is that a program will open a file and mark it's status to show what other programs are allowed to do with it (i.e. if you are actively editing a file, it will be marked read-only). When the program is through with the file, it returns the status to normal to allow other programs to use it.
Sometimes a program is unable to return a file's status to normal. A corrupt folder is one of those things that can cause this. You have to determine if Extension Manager is in error thinking the files are in use, or the files are marked incorrectly. I'm guessing it's a problem with the folder.
You say that you have a lot of extensions. It's possible that is a problem as well. You may have reached a limit. You could try uninstalling one to see if it makes a difference
neo314
I think it is just weird. What I really want to know is what designates the file as in use. I was hoping it would be an xml file I could delete that would be recreated at startup like the cache file or something.
Instead I just futzed around. Deleted some things moved some things, rebooted a couple of times and everything uninstalled and reinstalled just perfectly...
tia371500
This happened to me
I had this happen to me once with Dreamweaver. Not sure if it is the same thing for the WA plugin. I spoke with Adobe... was instructed to open the Windows Task Manager (ctrl-alt-delete) and click on processes tab.
I was having trouble with Dreamweaver still running but closed on my desktop. The rep instructed me to end process on dreamweaver.exe.
Not sure if that helps but... it worked for me.
