SEO work on code
Thread begun 9/26/2009 4:02 pm by keith309207 | Last modified 10/19/2009 11:38 am by Jason Byrnes | 4954 views | 7 replies |
keith309207
SEO work on code
I am trying to use css in the CSS Sculptor 3, to move the code and content of the middle column (in a 3 column fixed width/faux column layout) to the top of the page, but still have the style work.
I am trying to ensure that the centre content appears at the top of the page from an SEO perspective.
Has this been done before, and if so how?
Keith
A basic three column layout will have the following structure:
html:
<body>
<div id="outerWrapper">
<div id="contentWrapper">
<div id="leftColumn1"><left column content></div>
<div id="rightColumn1"><right column content></div>
<div id="content"><main content></div>
</div>
</div>
</body>
You can reorder the divs in the code to have the content div listed first:
html:
<body>
</div>
</div>
</body>
This change will not effect the layout.
keith309207
Code change
hi,
I think I must have some strange CSS somewhere as when I move the content to the top of the page, the left and right menus shift to the bottom. I have inherited the CSS code from a developer so am trying to see what might cause it.
index.html
keith309207
blank template
even when I do it with a new template using sculptor 3 it does the same..it pushes the side menus below.. maybe something to do with the float?
So, it turns out my statement "This change will not effect the layout" was not true.
It is not possible to reorder the divs with out affecting the layout. The problem is that floated divs such as the side navigation divs must be declared before non floated element such as the main content.
keith309207
Suggestions
Ok, I can understand that advice can be wrong. However I would have thought that the ability to build an optimised framework would be automatically built into a commercial "paid for" product.
Can someone who works for the webassist suggest the answer rather.
K
keith309207
Suggestions
I understand that the comment earlier was an error, however if you could just solve the problem of the comment wherby u said "side navigation divs must be declared before non floated element such as the main content"... then I would be able to live happily ever after!
That comment was intended as explanation of why the main content cannot come before the side divs.
the side divs are floated, so must be before the main content div.
You will not be able to move the main content div to be before the side divs because of this.
