Question over Multiple Client_Insert pages
Thread begun 9/25/2009 11:02 am by minindy388290 | Last modified 8/18/2014 8:28 am by Jason Byrnes | 5557 views | 5 replies |
minindy388290
Hello, I am trying to create multiple client_insert pages due to the fact that I do not want all of the customer input fields on one page. My question is how do I connect client_insert pages? I have already created the first page and would like to create a next button at the bottom to go to the next page to keep entering information.... however I am having a bit of trouble figuring out how to do that. If anyone has any tips for me I would greatly appreciate it!
when creating a form that spans multiple pages, you need to use hidden form elements to capture the information from the previous page.
for example:
on the first page the form will look like:
<form id="form1" method="post"  action="">
  First Name
  <input type="text" name="FName" id="FName" />
  <br />
  Last Name
  <input type="text" name="LName" id="LName" />
  <br />
  <input type="submit" name="button" id="button" value="Submit" />
</form>
on the second page, there will be hidden form elements to capture the first name and last name, as well text boxes to enter new information such as billing address:
    Address
    <input type="text" name="address" id="address" />
    <br />
    City
    <input type="text" name="city" id="city" />
    <br />
    State
    <input type="text" name="state" id="state" />
    <br />
    Zip Code
    <input type="text" name="zip" id="zip" />
    <br />
    <input name="FName" type="hidden" id="FName" value="<?php echo((isset($_POST["FName"]))?$_POST["FName"]:"") ?>" />
    <input name="LName" type="hidden" id="LName" value="<?php echo((isset($_POST["LName"]))?$_POST["LName"]:"") ?>" />
  <br />
</form>
anonymous
Form builder on steriods
I will attached a file of a typical farm application. Please note... If a prospect has more than one home on the farm and more than one Barn on the farm, I would need to be able to have a " Add another home" "Add another Barn" function as well.
Thank tremendously
with the complexity of this form, I would use security assist to have the person first create an account, and login.
this is a very cumbersome form to have on one page, and you will want a way to track the information to the person.
When the person logs in their ID is stored in a session variable.
I would break the form into smaller chunks and have a separate page for each piece of the form, on each page, store the form data to a database table using the insert record behavior, each form will insert to a different table.
each table should have a column to store the users ID session to relate the data being inserted to the user.
on the main users page, have links to each form
the user could use the barn insert page to add multiple barns
or use the home insert page to add multiple homes.
info298111
5-page form
I have a 5-page form with 5 upload fields on form5. Uploads are stored in a database etc.
When starting the record ID is retrieved. When moving from page 1 to page 2 the existing record and previously uploaded files are deleted to prevent info being mixed.
Following this guide, I can bring form contents from form1 to form2. That works fine, but it will be lost on form3. On form3 only the contents from form 2 are transferred. I need to have the data persistent until page 5 where all data inserted will be mailed.
Pse advice
store the data from each into session variables, the sessions will persist from page to page.
