Have ASP Site with Access Database - Now want to convert to SQL
Thread begun 9/25/2009 2:09 am by karen.marley367377 | Last modified 9/28/2009 2:07 am by karen.marley367377 | 3320 views | 3 replies |
karen.marley367377
Hi - have a site using ASP and Access - but now need to convert the database to MYSQL.
I have a couple of questions:
Do I have to convert the ASP to PHP - is there a way to do this - other than rebuilding the site?
If the language remains as ASP -which is the method to connect to the MYSQL database.
It would be better to switch to PHP with MySQL.
It is possible to continue using ASP with my SQL, but not recommended.
The following page may help with creating a connection string in ASP to connect to MySQL:
mysql
Our tools will no longer be supporting ASP However.
There is no conversion utility to convert an ASP site to PHP, you would need to recreate the site using PHP.
anonymous
Go with PHP... it's all the rage :D.
karen.marley367377
Thanks Jason, I thought that might be the case! X
