What happened to my preset values?
Thread begun 9/24/2009 9:15 pm by Stevebo | Last modified 9/25/2009 12:34 pm by Eric Mittman | 1712 views | 1 replies |
Stevebo
So I inserted a form chose my form type, then the preset I saved, then the design that I used to create a form previously. The form shows up as I created it, BUT, all the font/point settings I had made for the form, labels, fieldset, legend, and combo group were all gone. Also all the stuff I entered for the fieldset backgrounds and legend positioning was also gone. It appears that it reverted back to the default values that were associated with the Registration form. What could have happened to these settings given that I always saved as a preset?
steve
When you are customizing the design and save a preset it will be specific to that design. If you edit your custom preset for the design you will need to overwrite the existing one with your updated one.
When I do this I'm able to use the custom preset for my design without issue. After I create the form on the page I can then edit the design directly, or choose the preset to edit from the edit form option.
In regards to the preset you created for the design can you see it as the selected design preset? When you edit the preset does it have all of your edits or the defaults? Did you ever edit the default and save it over your custom preset? Please post back with some more info on these so that we can try to determine what may be going on with what you are experiencing. Something else that may be helpful would be to go into the preset manager and export the design that you made a custom preset for. I should be able to import this and take a look at it.
