Disappearing list background
Thread begun 9/24/2009 4:26 pm by paul389676 | Last modified 9/25/2009 7:02 pm by paul389676 | 5487 views | 5 replies |
paul389676
I have a task to add menus to a number of existing dreamweaver templates and purchased menu writer to do this. However, I find that the menus do not work in IE and dreamweaver suggest the DISAPPEARING LIST BACKGROUND bug.
index.cfm?event=findByTextId&productid=1&textid=DISAPPEARING_LIST_BACKGROUND
Will menu writer not work for me or is there a solution?
thx
PS I subscribed to the monthly ongoing $19.99 program
-paul
There are a few things that may cause this, to start with though:
Make sure you set a width and a height on the menu items. IE 6 will not work correctly if you use a percentage for the width and height, or if you use auto. you need to use a pixel measurement.
If you still having a problem, send a link top your menu so we can take a look at the css and see what is wrong.
paul389676
Here's a sample.
Before adding menu writer
index2.html
After adding menu writer
index.html
Also, please note that in IE8 with google toolbar installed, adding a menu writer menu resulsts in the very bizarre "This page is in Portuguese" google translate header frame
thx
In actual fact, the problem is not the Disappearing list background bug. That bug occurs can occur when the menu is placed in a div that has the position: relative attribute. You are using a table based layout however, the menu is not in a div, it is in a TD Cell.
The real problem is that the menu_ie.css file for the menu to render in IE 6 is not uploaded tho the server.
make sure to upload the entire CSSMenuWriter menu writer folder to the server.
another problem i see on your page is that is missing the doctype tag. Add the following at line 1 to improve standards compliance:
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN" "http://www.w3.org/TR/html4/loose.dtd"><html>
also I see 2 charset meta tags:
<meta http-equiv="Content-Type" content="text/html; charset=utf-8">
<meta http-equiv="Content-Type" content="text/html; charset=windows-1251">
one of them should be removed.
paul389676
Here are the files that got uploaded to the server. Which file is missing and where should I get it from?
[root@bali demo]# ls
CSSMenuWriter images index2.html index.html style.css
[root@bali demo]# cd CSS*
[root@bali CSSMenuWriter]# ls
cssmw cssmw0 cssmw1 cssmw2
[root@bali CSSMenuWriter]# ls cssmw
menu.css menu_ie.css menu.js menustyle.xml treexml.xml
[root@bali CSSMenuWriter]# ls cssmw0
[root@bali CSSMenuWriter]# ls cssmw1
[root@bali CSSMenuWriter]# ls cssmw2
menu.css menu.js
paul389676
As per your suggestion, this doctype at line 1 appears to make the menu work.
