Shipping Address Book
Thread begun 9/24/2009 2:20 pm by eric284736 | Last modified 9/29/2009 5:12 pm by eric284736 | 6418 views | 10 replies |
eric284736
I want to create an address book for a customer to add shipping addresses for different locations. When they checkout and get to the shipping information they could have a drop down box to select the address they want.
I was thinking I could have this pull from a session - if they select the name that would set the session and the page would refresh with that address filling out the shipping form. Just like the checkbox for the Shipping is the same as billing, except a drop down.
Would this be possible or am I missing an easier method?
thanks,
Eric
You would need to create a shipping address table. the shipping address table should contain a foreign key relationship to the users table:
shippingID - Pirmary Key
shippingUserID - Foreign key to users.userID
ShippingFirstName
shippingLastName
etc...
You will need to make sure that the user is logged in before they can add shipping addresses. see the "How to apply Login/Register functionality to your Checkout Process" tutorial in the How To section of the eCart support page:
ecart/
When the user logs in, a session variable will be created with the unique primary key from the users table. In the Add Shipping Address form, store that session variable in the shippingUserID column.
To display a select list with the different shipping addresses the have entered, create a recordset the queries the shipping address table. Filter the shippingUserID column on the userID session variable.
eric284736
Thanks Jason! Got that setup, so once they select a name from the drop down how to I get that to fill into the shipping part of the form?
thx
Eric
your drop down should have the value set to the shippingID column.
Create another recordset that filters the shipping address table on the select list, and use that recordset to populate the shipping form fields.
eric284736
Okay, but I want it to fill out the shipping part so How to I get it to refresh the checkout page to include the selected shipping address in the shipping form?
OR should I have the address selection in a pop up window and when selected address is chosen the window closes and refreshes the checkout page with the correct ship to address?
thx
Eric
eric284736
Jason,
Let me explain a little about the current setup. The checkout page is the standard page with the billing and shipping info on the same page.
So how do I bind the ship to form section to the recordset if they have not selected one yet and still keep the "Check the box if shipping is the same as billing" and still validaye the form so the required information is entered.
Would it be better to have this spread across two pages or is it possible to keep the entire function on the same page?
thanks,
Eric
You could keep the entire thing on one page. Add the select list to a different form. When a shipping address is selected, that form posts to the page, and filters the recordset to populate the shipping form elements. The billing and shipping form will post over to the confirm page.
eric284736
Jason,
Okay I have my page setup and I have the ship to form values binded to the filtered recordset for the shipping address selected.
Because it is binded and when they first get to the page the filtered recordset is empty until they select an address. That of course will throw an error on the form and it does not display. I added a Show If statement for the shipping fields, but now the Check if shipping address is same as billing will not work initially because the shiiping fields are not shown.
how can I bind the shipping fields and still use the Shipping same as billing checkbox?
thx
Eric
Instead of a show if around the shipping fields, use the validation tools from CSS Form builder to validate the form so that it can only be submitted if the shipping information is filled in.
eric284736
I don't have the CSS Form Builder and this is in ASP.
I have attached the page so you can see the code I have in place.
thx
Eric
