Digital File Pro - not uploading file and writing to DB
Thread begun 9/24/2009 10:13 am by sandy170299 | Last modified 9/24/2009 12:35 pm by sandy170299 | 2366 views | 2 replies |
sandy170299
Digital File Pro is not uploading my file nor is it writing to the database. Here is my code.
<?php require_once('../Connections/studio120.php'); ?>
<?php require_once("../WA_DataAssist/WA_AppBuilder_PHP.php"); ?>
<?php require_once("../WA_DigitalFilePro/HelperPHP.php"); ?>
<?php require_once("../WA_iRite/WARichEditorPHP.php"); ?>
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
$theValue = ($theValue != "") ? "'" . doubleval($theValue) . "'" : "NULL";
break;
case "date":
break;
case "defined":
break;
return $theValue;
$ParamID_WADAmenus = "-1";
if (isset($_GET['ID'])) {
$ParamID_WADAmenus = (get_magic_quotes_gpc()) ? $_GET['ID'] : addslashes($_GET['ID']);
mysql_select_db($database_studio120, $studio120);
$query_WADAmenus = sprintf("SELECT ID, menuName, pageContent, pageTitle, photo FROM menus WHERE ID = %s", GetSQLValueString($ParamID_WADAmenus, "int"));
$WADAmenus = mysql_query($query_WADAmenus, $studio120) or die(mysql_error());
$row_WADAmenus = mysql_fetch_assoc($WADAmenus);
$totalRows_WADAmenus = mysql_num_rows($WADAmenus);?>
// WA_UploadResult1 Params Start
$WA_UploadResult1_Params = array();
// WA_UploadResult1_1 Start
$WA_UploadResult1_Params["WA_UploadResult1_1"] = array(
'UploadFolder' => "../",
'FileName' => "[FileName]",
'DefaultFileName' => "".$row_WADAmenus['photo'] ."",
'ResizeType' => "2",
'ResizeWidth' => "150",
'ResizeHeight' => "120",
'ResizeFillColor' => "#FFFFFF" );
// WA_UploadResult1_1 End
// WA_UploadResult1 Params End
WA_DFP_SetupUploadStatusStruct("WA_UploadResult1");
if(isset($_POST["Update_x"])){
WA_DFP_UploadFiles("WA_UploadResult1", "photo", "2", "[NewFileName]_[Increment]", "true", $WA_UploadResult1_Params);
// WA Application Builder Update
if (isset($_POST["Update_x"])) // Trigger
$WA_connection = $studio120;
$WA_table = "menus";
$WA_redirectURL = "menus_Results.php";
$WA_keepQueryString = false;
$WA_indexField = "ID";
$WA_fieldNamesStr = "menuName|pageContent|pageTitle|photo";
$WA_fieldValuesStr = "".((isset($_POST["menuName"]))?$_POST["menuName"]:"") ."" . "|" . "".((isset($_POST["pageContent"]))?$_POST["pageContent"]:"") ."" . "|" . "".((isset($_POST["pageTitle"]))?$_POST["pageTitle"]:"") ."" . "|" . "".$WA_DFP_UploadStatus["WA_UploadResult1"]["serverFileName"] ."";
$WA_columnTypesStr = "',none,''|',none,''|',none,''|',none,''";
$WA_comparisonStr = "=|=|=|=";
$WA_where_fieldValuesStr = "".((isset($_POST["WADAUpdateRecordID"]))?$_POST["WADAUpdateRecordID"]:"") ."";
$WA_where_columnTypesStr = "none,none,NULL";
$WA_where_comparisonStr = "=";
$WA_where_fieldNames = explode("|", $WA_indexField);
$WA_where_fieldValues = explode("|", $WA_where_fieldValuesStr);
$WA_where_columns = explode("|", $WA_where_columnTypesStr);
$WA_where_comparisons = explode("|", $WA_where_comparisonStr);
$WA_connectionDB = $database_studio120;
$updateParamsObj = WA_AB_generateInsertParams($WA_fieldNames, $WA_columns, $WA_fieldValues, -1);
$WhereObj = WA_AB_generateWhereClause($WA_where_fieldNames, $WA_where_columns, $WA_where_fieldValues, $WA_where_comparisons );
$WA_Sql = "UPDATE `" . $WA_table . "` SET " . $updateParamsObj->WA_setValues . " WHERE " . $WhereObj->sqlWhereClause . "";
if ($WA_redirectURL != "") {
<head>
<title>Update menus</title>
<link href="../WA_DataAssist/styles/Ultramodern_Slate.css" rel="stylesheet" type="text/css" />
<link href="../WA_DataAssist/styles/Verdana.css" rel="stylesheet" type="text/css" />
</head>
<body>
<div class="WADAUpdateContainer">
<?php if ($totalRows_WADAmenus > 0) { // Show if recordset not empty ?>
<form action="menus_Update.php?ID=<?php echo(rawurlencode($row_WADAmenus['ID'])); ?>" method="post" name="WADAUpdateForm" id="WADAUpdateForm">
<div class="WADAHeader">Update Record</div>
<table width="75%" border="0" cellpadding="0" cellspacing="0" class="WADADataTable">
<tr>
<th valign="top" class="WADADataTableHeader">menuName:</th>
<td valign="top" class="WADADataTableCell"><input type="text" name="menuName" id="menuName" value="<?php echo(str_replace('"', '&quot;', $row_WADAmenus['menuName'])); ?>" size="32" /></td>
</tr>
<tr>
<th valign="top" class="WADADataTableHeader">pageContent:</th>
<td valign="top" class="WADADataTableCell"><?php
// WebAssist iRite: Rich Text Editor for Dreamweaver
$WARichTextEditor_1 = CreateRichTextEditor ("pageContent", "../WA_iRite/", "100%", "350px", "Custom", "../custom/menus_Update_pageContent1.js", "".$row_WADAmenus['pageContent'] ."");
?></td>
</tr>
<tr>
<th width="25%" valign="top" class="WADADataTableHeader">pageTitle:</th>
<td valign="top" class="WADADataTableCell"><input type="text" name="pageTitle" id="pageTitle" value="<?php echo(str_replace('"', '&quot;', $row_WADAmenus['pageTitle'])); ?>" size="32" /></td>
</tr>
<tr>
<th valign="top" class="WADADataTableHeader">photo:</th>
<td valign="top" class="WADADataTableCell"><input name="photo" type="file" id="photo" size="55" /></td>
</tr>
</table>
<div class="WADAButtonRow">
<table class="WADADataNavButtons" border="0" cellpadding="0" cellspacing="0">
<tr>
<td class="WADADataNavButtonCell" nowrap="nowrap"><input type="image" name="Update" id="Update" value="Update" alt="Update" src="../WA_DataAssist/images/Slate/Ultramodern_update.gif" /></td>
<td class="WADADataNavButtonCell" nowrap="nowrap"><a href="menus_Results.php" title="Cancel"><img border="0" name="Cancel" id="Cancel" alt="Cancel" src="../WA_DataAssist/images/Slate/Ultramodern_cancel.gif" /></a></td>
</tr>
</table>
<input name="WADAUpdateRecordID" type="hidden" id="WADAUpdateRecordID" value="<?php echo(rawurlencode($row_WADAmenus['ID'])); ?>" />
</div>
</form>
<?php } // Show if recordset not empty ?>
<?php if ($totalRows_WADAmenus == 0) { // Show if recordset empty ?>
<div class="WADANoResults">
<div class="WADANoResultsMessage">No record found.</div>
</div>
<?php } // Show if recordset empty ?>
</div>
</body>
</html>
mysql_free_result($WADAmenus);
For file uploads to occur, the forms encoding type needds to be set to multipart/form-data.
change the form tag:
<form action="menus_Update.php?ID=<?php echo(rawurlencode($row_WADAmenus['ID'])); ?>" method="post" enctype="multipart/form-data" name="WADAUpdateForm" id="WADAUpdateForm">
sandy170299
Hah! Thank you, Jason :) You rock once again! I created everything with DataAssist and neglected to check that part of the form.
